TKO600 for 455
Old Oct 24, 2020 | 08:09 AM
VinMichael's Avatar
TKO600 for 455
Can our cranks be modified to accept a modern transmission like a TKO600 or T56? Lots of cool offerings out there these days for Chevys. Can we keep up with the times?
Old Oct 24, 2020 | 10:57 AM
Qwik71442's Avatar
Full-time Taxpayer
Absolutely
Old Oct 24, 2020 | 06:05 PM
VinMichael's Avatar
What needs to be done to the crank to accept input shaft?
Old Oct 24, 2020 | 11:12 PM
Killian_Mörder's Avatar
If the crank already has a shaft bushing, it should be as easy as a Chevy swap. Here, a how-to article doesen't want anybody in Europe doing likewise:
Old Oct 25, 2020 | 07:24 AM
Bubba68CS's Avatar
If the crank is a manual transmission crank, then nothing needs done to it. If it’s an automatic transmission crank, it needs to be drilled for the pilot bearing.
If you’ve got the manual transmission crank, or are already doing work on an automatic transmission crank, that is probably the easiest part of the swap. If you have an automatic crank and don’t plan to remove it from the car, it becomes a big deal.
I am swapping from an automatic to Tremec Magnum. My crank was already being pulled for a rebuild so it was no big deal to machine the end.
Old Oct 25, 2020 | 11:52 AM
VinMichael's Avatar
I have several extra cranks, none of them are drilled for a manual. What tooling is needed and what dimensions are required for the hole needing to be made?
Old Oct 25, 2020 | 01:06 PM
DG65's Avatar
Dimensions
Old Oct 25, 2020 | 01:07 PM
DG65's Avatar
Crank
Have a machine shop do it. Credit to Joe P for drawing
Old Jan 2, 2021 | 11:21 AM
jim4442's Avatar
Originally Posted by DG65
DG-I have a 455 crank-trying to determine if drilled for manual or auto-end has a series of spaced holes-can you describe what I should look for?
thanks and pls send direct email jlincoln98@yahoo.com
thanks Jim
Old Jan 2, 2021 | 11:34 AM
Thirdcoast's Avatar
Lightbulb New Tremec TKX
I have been looking at the new Tremec TKX for my 64 F85. It is supposed to fit A Bodies with no tunnel mods needed..
This transmission is an all new smaller case and designed to handle up to 600 Tq and 500 HP with shifting up to 7500 RPM.
Two models, wide ratio and close ratio.
There are some videos on YouTube with pretty indepth discussions on this tranny.
Thirdcoast
Old Jan 4, 2021 | 07:19 AM
brownbomber77's Avatar
The TKO trans fits behind the Olds no problem however, yes, the trans tunnel needs to be cut to accept the wider body of the TKO. I did it on my '77. Won't be able to tell once you get the carpet in so doesn't matter much. You're obviously not keeping the car stock so, speaking practically, does it matter if you have to cut the floor?
The tremec TKX is like, twice the price of the TKO isn't it?
Old Jan 4, 2021 | 07:23 AM
Thirdcoast's Avatar
Tremec
Nope, the TKO is $2595 and the TKX is $2795.. Trans only..
No cutting with the TKX (supposedly)
TC
Oldsmaniac
Apr 2, 2016 05:04 PM
rad
Feb 28, 2016 09:05 AM
oldsmoboogie
Jun 23, 2013 09:19 AM
agtw31
Aug 25, 2010 08:43 PM
kona-jack
Aug 27, 2009 10:28 AM
