th400 wont shift in drive to 3rd
Old Aug 17, 2012 | 09:54 AM
cut123's Avatar
If i manuel shift, shifts good and hard in all gears. When trans is in drive wont go to third! Ordered a new adjustable vacuum modulator today. Any other ideas, and yes linkage is correct.
Old Aug 17, 2012 | 03:54 PM
tru-blue 442's Avatar
Old School Olds
Filter change.
Old Aug 17, 2012 | 04:00 PM
OLDSMORAT's Avatar
Pop the cover off the govenor. Pull it out check the weights and the piston to see if they are free moving.
Old Aug 17, 2012 | 04:17 PM
Rickman48's Avatar
X2 on the governor - check the gear, too.
Make sure the kickdown switch is functioning correctly.
Old Aug 17, 2012 | 05:13 PM
All of the above!
Old Aug 18, 2012 | 12:54 AM
cut123's Avatar
I don't have a kickdown switch hooked up, didn't know this could cause not to shift into third, when in drive shifts from first to second then nothing. But if I pull my shifter down to first then move to second it shifs then to drive it shifts fine.
Old Aug 29, 2012 | 04:22 PM
cut123's Avatar
Still need help. adjusted new modulator shift better but still no 3 in drive. Ordered gov kit. any suggestion on spring weight 3.73 hears th400
Old Sep 1, 2012 | 09:40 PM
johnfmstr's Avatar
when you take off in drive at what speed does it change gears. and do you have good vacaum. at the modulator least 14+ iom.
Arrowstorm
May 20, 2014 05:23 PM
Big Leche
Feb 3, 2014 01:15 PM
wannaride
Nov 18, 2010 03:53 PM
Batmobile66
Jun 18, 2010 01:27 PM
65az
Aug 18, 2009 11:43 AM
