th400 tranny HELP
Old Feb 8, 2008 | 06:00 AM
Redog's Avatar
Unhappy th400 tranny HELP
As the title says:
I need help figureing out something with my 400 tranny.
The speedo provision hole is CASTED into the block, it's not a freeze plug. I was going to fix up the transmission with a new convertor, flexplate, shift kit etc and add in the speedo gears, but work stop before it started. My mech didn't want to cost me too much cash so he stopped work until I can figure out how to drive the speedo.
I've been searching for 2 days now on the internet and I'm no closer to where I was before I started. I'm spinning my wheels I guess you can say.
The only thing I can think of so far is a 700 r4 or a th350 tail housing but I do not know if they will bolt right up. I think the 4L60 tail housing is the same lenght as my 9" tail I have now.
Any insight, leads, answers will be great help.
Thank you in advance
Old Feb 8, 2008 | 09:53 AM
Can't you just get a TH 400 tailshaft with the speedo gear attachment? I don't really understand what your problem is. Sorry.
Old Feb 8, 2008 | 11:27 AM
Oldsguy's Avatar
Past Administrator
There is no hole in the casting because that transmission was originally in a late sixties B body like my '69 Delta 88 I used to own. They drive the speedometer from the driver's front spindle via a cable directly to the speedo, not from the transmission. I think Jesse is correct, changing the tailshaft would allow you to attach the speedo cable to the transmission but you would also have to get the correct ratio drive gear. There may be some internal modifications to the tranmission as well. I know this was mentioned before here at this site. Maybe it was Joe or TexasRed. Not sure.
Old Feb 8, 2008 | 08:45 PM
Redog's Avatar
HAven't found anything like that.
Thinking I'm going to have to go with a new case
Old Feb 9, 2008 | 05:56 AM
If nothing can be done to your existing case then maybe you should look into an aftermarket speedometer with a vehicle speed sensor. I know you can buy them for street rods and such.
Old Feb 9, 2008 | 07:07 AM
2blu442's Avatar
I believe the speedometer attachment is in the side of the main case on these trannies. So if you really want to use this trannie instead of getting a different one then Olds64 has a good idea. The ones I've seen are for electric speedometers and attach a magnetic pickup on the driveline. It will read the electric "pulses" as the driveline rotates and convert that to a signal that gives the speed of your car.
Old Feb 9, 2008 | 12:48 PM
Redog's Avatar
My mecan get me a new case for $75 to $100 and then rebuild the tranny (building it up a bit) so I think I'm going that route but after April 14th (Union contract / strike watch) Plus the Alero just cost me $550 for the ign lock cyl and passlock system, and I need a new MAF for it
Beob
Aug 6, 2012 12:13 PM
oldjunk
Aug 3, 2012 06:00 PM
dallasite21
Feb 11, 2012 06:37 AM
ls442
Nov 11, 2010 10:45 PM
oldolz
Jul 13, 2010 08:22 AM
