Th400 tailshafts
Th400 tailshafts
Ok I want to get this straightened out.
1.-There is a short shaft, a medium shaft and a long shaft, correct?
2-shortys are in A bodys like a 71 cutlass??
3-Mediums are in 70's delta 88s?
4.-and the real long ones are in Chubby suburbans and stuff like that?
5.-Is it 4'', 8'' and 12'' or what? I'm kinda confused here.
6-Or are there only 2... long and short?
7.-Is there a medium 375 or something?
I would think the longest ones would be the best, because there is less driveshaft to transfer power through, or twist.
However the longer ones that I have seen
go for cheaper.
I myself have only had to deal with th350s, always with 4 '' tailshafts.
80 delta
72 skylark
79 camaro.
etc etc
go for cheaper.
80 delta
72 skylark
79 camaro.
etc etc
I clipped this from a web site a long time ago. Not sure where (possibly TCI) but many transmission sites have detailed info on trans sizes.
A - overall length
B - Length from bell housing face (surface that mounts to engine) to tail (A-B=Tail shaft length)
C - Length from bell housing face to trans mount
D - Distance between trans mount bolts
E - Bell housing width
TH350 (bellhousing pattern - Chevrolet, BOP, Fit-All)
A - overall length
Style
A
B
C
D
E
6" tailshaft
27 11/16
21 5/8
20 3/8
3 ¾
19 1/8
9" tailshaft
30 11/16
21 5/8
20 3/8
3 ¾
19 1/8
12" tailshaft
33 27/32
21 5/8
20 3/8
3 ¾
19 1/8
TH400 (bellhousing pattern - Chevrolet, BOP)A
B
C
D
E
6" tailshaft
27 11/16
21 5/8
20 3/8
3 ¾
19 1/8
9" tailshaft
30 11/16
21 5/8
20 3/8
3 ¾
19 1/8
12" tailshaft
33 27/32
21 5/8
20 3/8
3 ¾
19 1/8
Style
A
B
C
D
E
C tailshaft
28 3/8
24 5/16
26 15/16
4 ¼
20
D tailshaft
33 27/32
24 5/16
27 15/16
4 ¼
20
13" tailshaft
37 7/8
24 5/16
27 21/32
1 ¾
20
2004R (bellhousing pattern - BOP, Fit-All)A
B
C
D
E
C tailshaft
28 3/8
24 5/16
26 15/16
4 ¼
20
D tailshaft
33 27/32
24 5/16
27 15/16
4 ¼
20
13" tailshaft
37 7/8
24 5/16
27 21/32
1 ¾
20
Style
A
B
C
D
E
All
27 11/16
integral tailhousing
27
3 ¾
19 1/8
A
B
C
D
E
All
27 11/16
27
3 ¾
19 1/8
it was very random
every 80s truck i have ever parted with the 400 trans in it was always the short tail
overal trans length including the output yoke(bolt on style) is always the same 31.5" as the 9" tail th350
its crazy like that
the old long tail th400 were way long time ago in the big cars
not common at all anymore
this goes for regular 3L80/th400 only and only 4x2 version
not for the 3L80HD or any other 400 variants
4x4 was a whole different tailshaft than 4x2
the 3L80HD started in 87 and up in the trucks and was 34.5" long overall
and had the 27 spline output like a th350 and 700r4 and so on
tag code LJA and HD cast on the case at the bellhousing top side
i own one and have seen two so far
it is complicated
i have found that the charts and info online that show lengths of GM trannies that are often 1" incorrect
i dont know why
when you put a tape measure on the actual trannies and measure them they are actually 1" longer than stated online
375 and 375B were combinations of the th350 and the th400,
one was a 400 case and the other was a 350 case
th375:
http://en.wikipedia.org/wiki/Turbo-H...Hydramatic_375
http://en.wikipedia.org/wiki/Turbo-H...L80_.2F_3L80HD
its crazy like that
it is complicated
i dont know why
th375:
go for cheaper.
80 delta
72 skylark
79 camaro.
etc etc
go for cheaper.
80 delta
72 skylark
79 camaro.
etc etc
uhmmm... th350 were 3, 6, 9, and 12" tails
so..
3" were in 4x4
12" were in some late 70s wagons
6" were in 69-72 trucks and in most cars
9" were in all 73-up trucks
you guys are so very amusing
ya'll must not have owned very many gm products or been into very many
wow.,
TRW
January 21st, 2011 05:38 AM
