TH400 leak
Old Sep 26, 2025 | 02:22 PM
Chuxter's Avatar
1970 Cutlass Supreme
TH400 leak
I have a 1970 Cutlass Supreme that I have put a 455 and a TH400 transmission out of a 1974 Olds 98 into. My problem is when it is sitting parked in my garage and it gets hot in the transmission leaks fluid everywhere. I believe it is leaking through the yoke. I have installed a new tail shaft seal and a new oring on the out put shaft. I am at a loss as to why it is still leaking like this. It is not the original drive shaft. The drive shaft was shortened when we went with the long tail shaft transmission. Any ideas?
Old Sep 26, 2025 | 02:55 PM
When you shortened the drive shaft did you make sure the yoke was the same diameter as the OE one?
Old Sep 26, 2025 | 04:02 PM
Your statement doesn't provide confidence in having identified the "source" of the leak. Don't guess, save time & headaches. Clean up the casing as best you can. Add some UV dye to the fluid. In short order (after a short drive) you'll find the source of the leak. Dye ~$8-10, small UV pen light ~$10 (or use the UV light from the teenage kid next door). Stevie Wonder could find that leaking trail. This is the reason a mechanic uses these dyes. Dye & UV pen light are readily available at most reputable auto parts supplies stores.
Old Sep 26, 2025 | 05:08 PM
oldsconv's Avatar
I remember someone joking that the TH400 can leak anywhere between the bellhousing and the tailshaft. I have same issue on my 70 Cutlass SX even after having someone rebuild the TH400 for me. Shift shaft seal is a common one. front seal, rear seal, pan gasket, dipstick tube o-ring, etc. If shift shaft has a groove worn in it, the seal won't stop leaks and need to replace shift shaft. Some people pound in 2 shift shaft seals and that sometimes works. Rear yoke seal could be an issue and I think there is also a bronze bushing in there that could be bad and causing leaks. Or rear yoke has a groove worn in it, so the new seal doesn't seal properly. If pan is warped, that can cause leak - Felpro makes a thicker pan gasket that sometimes helps. Lots of places to check - I would put a big piece of cardboard underneath and see if you can pinpoint it.
Old Sep 26, 2025 | 06:03 PM
Chuxter's Avatar
I'm sure it's leaking through the hole in the center of the yoke. The fluid runs out behind the u joint.
Old Sep 27, 2025 | 01:26 AM
Brankoy's Avatar
Check the TH400 vent (make sure it’s clear), verify fluid level hot, and inspect the slip-yoke for a tiny end hole plug it if present. Worn yoke surface or loose output bushing can also cause that leak.
Old Oct 1, 2025 | 11:32 AM
Chuxter's Avatar
So the th400 does not need the vent hole through the yoke?
Pigs Fly Garage
Jun 30, 2023 01:31 PM
kbdecatur
Drivetrain/Differentials
Apr 23, 2023 07:30 AM
XTREMEGSXR
Jan 5, 2013 02:16 PM
1968ragtop
Apr 11, 2011 02:54 AM
jojo66
Apr 29, 2008 12:22 PM
