TH400 Kickdown Assembly
Hi Folks
My Cutlass came to me with a TH400, but I noticed there was no kickdown assembly, although the wiring was there for it. Somehow I believe the car (originally a 350CID) but now a 455 came with a Turbo 350 Tranny, but I am not sure.
I got a bracket, but now am having difficulty installing it.
Please see pics.
http://roberttullierproductions.com/kick-1.jpeg
I am thinking I need to remove the tab indicated in pic-2.
http://roberttullierproductions.com/kick-2.png
as it seems to be interfering with the switch as shown in pic-3
http://roberttullierproductions.com/kick-3.png
Lastly, I am wondering if I move the cable to the other opening on the pedal, do I need to have the throttle cable come through the hole in pic-4?
http://roberttullierproductions.com/kick-4.png
THank you for any insight.
TP
Please see pics.
TP
Your car was originally equipped with a TH350 and yes, you have the TH350 accelerator. You need to remove that tacked-on tab from the accelerator. The accelerator cable shouldn't change where it comes through the firewall - it's the upper of the two square holes.
The accelerator cable always uses the upper hole in both the firewall and the pedal. On TH350 cars the kickdown cable uses the lower hole in both the firewall and the pedal.
