TH400? Kickdown? 67-442
Anyone out there that can give me a quick lesson on kickdown hookup for a 400? I've seen an online article from Hi Performance Pontiac on how to wire a B&M switch. Is that all i need to try to follow?
Two questions:
67 442 (real car): Automatic, would it have come with a 400? or 350? (or did they come with either) I believe the seller thought it was a 400. It has an electrical/wire running into driver side if that is a clue.
Kickdown: It looks like 350/400 have different kickdown mechanisms. There is nothing at carb that I see, mechanical or electric, but I've been chasing other issues so far, so I haven't spent a great deal of time looking.
would it have been on carb or at accelerator somehow?
The kickdown circuit is pretty simple. Fused +12v is applied to one side of the switch. At WOT the switch closes, sending +12V to the trans. This activates the solenoid valve inside the trans, which switches hydraulic pressure to cause a downshift.
Thanks.
I came home at lunch and followed the wire from trans. It goes to exactly what you described. In this case it is a round 'pod' looking thing that connects to the throttle linkage.
All wires are there and connected.
The kickdown isn't working, so something isn't working right.
Thanks.
Can you still buy the original style switch?
If it comes out that the switch is no longer good, can you still buy a switch that fits?
Thanks for your help on the troubleshooting!!
d
d
