Th400 id
Old Sep 27, 2012 | 09:35 AM
pitfield1's Avatar
Th400 id
Hey guy's where will I find the build date on my 69 TH400 ? Thanks in advance
PIT 69 442 convert
Old Sep 28, 2012 | 08:21 AM
rcorrigan5's Avatar
Randy C.
I don't think you will find an actual build date for your transmission anywhere on the housing. You might find casting dates for the housing or tail piece but not an actual build date for the transmission itself. You will (or should) find a VIN derivative that ties the transmission to the car, though, if the tranny is original to the car. That number will be on the driver side, on a narrow vertical surface just above the pan, on the housing between two vertical ribs.
Randy C.
Old Sep 28, 2012 | 09:32 AM
pitfield1's Avatar
Randy C.
I found the vin# Just wondering about a build date. Thanks Randy
PIT 69 442 convert
TRW
Jan 21, 2011 05:38 AM
ls442
Nov 11, 2010 10:45 PM
78Delta88
Sep 18, 2004 09:58 PM
cutlass72
Jan 2, 2004 05:26 PM
