TH400 conversion
Old May 5, 2022 | 03:48 PM
Wingshot's Avatar
TH400 conversion
Hi guys,
I purchased my 1970 Cutlass Convertible for $50 in 1981. It’s been a long journey, but she’s finally getting to be the car I envisioned. I installed a 455 w TH400 trans that came out of a buddies 71 Olds 98. Motor and trans working great and I’m finishing the last of my open items. Kickdown on the trans is one of these. I know the kickdown is electric, what will I need to get this working?
Old May 5, 2022 | 04:49 PM
4speed455's Avatar
You need the kickdown switch and bracket that mounts under the gas pedal. If your car was originally a th350 it will have a clip on the gas pedal for the th350 kickdown cable, that may need to be ground off or you can replace the pedal. Your factory harness has the wiring built into it.
Old May 5, 2022 | 05:29 PM
Gorgeous Chevelle!!
Old May 5, 2022 | 06:00 PM
Wingshot's Avatar
Thanks for the reply. Will I need a cable assembly? Or does my existing harness have that?
PS. Chevelle stripes, Mustang bucket seats, yeah, yeah, yeah 😀
Old May 5, 2022 | 06:16 PM
4speed455's Avatar
Th350 kickdown uses a cable attached to the gas pedal. Th400 uses an electric switch attached to the gas pedal. All the factory harnesses have the wires for the th400 whether car came with one or not. You just need the switch and the bracket.
Old May 5, 2022 | 11:35 PM
The underdash wiring for the kickdown is there. You will need to add the wire to the engine harness. You need a male series 56 terminal, and a 1/4 inch female quick disconnect, and enough 16 wire to go from the firewall bulkhead connector to the trans kickdown connector.
id suggest using a hair dryer or heat gun to soften the sealer the factory put on the connector. The stuff Oldsmobile applied probably turned from sealer to glue during the Reagan administration. Loosen the bolt (it won’t come out) apply some heat, and wiggle the plug. You will need to look at the factory wiring diagram to figure out what cavity to insert the 56 terminal.
Old May 6, 2022 | 01:17 AM
The wire to the trans was built into every engine harness that year, no matter which trans the car came with. The 1970-72 harnesses have the two-wire trans connector to accommodate the pressure switch for TCS in addition to the TH400 kickdown. The TCS was used on every trans, so that wiring is already there. The TH400 kickdown wire was just not used on non-TH400 applications.
Old May 7, 2022 | 12:50 AM
Is the kickdown wire in the engine harness on the 68-69 cars? I knew the kickdown switch wire was included in the dash harness regardless of year, I thought the engine harness was transmission specific?
Old May 8, 2022 | 04:11 AM
Yes, the wire from the firewall connector to the trans is included in every A-body Olds built from 68-72.
Northern Custom Cruiser
Mar 6, 2016 07:32 AM
Skeetman
Jan 20, 2015 01:46 PM
Charly9g
Jul 18, 2014 03:13 PM
coppercutlass
Aug 4, 2013 07:21 PM
cutlass72
Jan 2, 2004 05:26 PM
