TH400 Case Finish - Is This Acceptable?
Old Jul 23, 2014 | 08:12 PM
costpenn's Avatar
Just tonight finished detailling my OW that I had rebuilt for my 70 project. (have not yet done the stencil thing) I really did not want to paint the case, so I spent a lot of time with wire brushes and the dremel tool trying to get a "as cast" aluminum look. I think it came out pretty well, but I plan on taking this car to the major shows next year, and would welcome opinions on whether you think it might look wrong when viewed in place. Thanks.
Old Jul 23, 2014 | 08:14 PM
costpenn's Avatar
Other side
Old Jul 24, 2014 | 06:46 AM
mrolds69's Avatar
It looks GREAT! A little shiny, perhaps...but way better than painted. It will look fine in your car. When you paint them, you lose all the detail like the natural finish vent tube, governor cover, etc. Did you clear the pan? The only thing that looks a bit off is the dipstick tube, it seems like it should be a lot darker I think.
Old Jul 24, 2014 | 07:44 AM
pogo69's Avatar
morgan
looks better than new
Old Jul 24, 2014 | 12:04 PM
Hairy Olds's Avatar
Shoveling Snow
With anything aluminum I degrease the part then use muratic acid to etch and brighten the part. Next step is to use Boeshield to protect the part and give it the just cast look. I also do this for all of my bare cast parts also.
Old Jul 24, 2014 | 01:21 PM
costpenn's Avatar
Hello - thanks for the tip on the dipstick tube. Going to look for something a little closer and redo it before installation. Here's a list of the things I did to it (including spraying a rust inhibiting clear on the pan)
1) Removed all the exterior accessories i.e dipstick tube, modulator etc..
2) Taped off all holes leading to trans interior
3) Wire brushed with various tools the case to remove corrosion and scale - this was 60% of the work I did.
4) Removed the pan. Sanded, then wire wheeled, then shot with the Krylon clear rust inhibitor paint.
5) Removed tail cover and gov. cover bolts. Wire wheeled and painted in phosphate paint.
6) Removed governor cover and wire wheeled. Painted in the same clear rust inhibitor paint used on the pan
7) Wirewheeled the dipstick handle and tube. Cleared the handle, but painted the tube in the Eastwood silver cad.
8) Painted the gear selector bell crank thing in the flat olive green paint.
9) Installed the gear shift cable bracket. Amazingly, the original plating on it was still good.
10) Installed the detailed harness clip
11) Installed the OW decal over my original still riveted in place tag. Man, that piece is nice - thanks Paul!
12) Painted the modulator and speedo hold in plates in Camoflauge black paint and reinstalled with phosphate painted bolts.
Old Jul 24, 2014 | 02:45 PM
dc2x4drvr's Avatar
Looks great! Very show worthy.
Old Jul 24, 2014 | 10:39 PM
johnnyjaws's Avatar
Looks SUPER
great U SHOULD BE PROUD OF UR SELF.!!
Old Jul 25, 2014 | 09:21 PM
Alex72cutty's Avatar
Looks good!!
Old Jul 25, 2014 | 10:24 PM
johnnyjaws's Avatar
u really cant see it once its all hooked up
Old Jul 25, 2014 | 10:26 PM
johnnyjaws's Avatar
get a nice b&m trans pan for it or one like it and make sure theres a drain plug in the pan makes for easy fluid changes
Old Aug 2, 2014 | 10:02 PM
johnnyjaws's Avatar
were do I get phosphate paint ?
Old Aug 2, 2014 | 11:47 PM
z11375ss's Avatar
Senior Moment Member
That's a lot of elbow grease!
twintracks
Apr 16, 2014 08:23 AM
atkinsom
May 14, 2013 07:48 PM
randomarrival
Dec 27, 2012 12:51 PM
Rocket331
Jul 8, 2012 07:29 PM
stellar
Feb 20, 2012 08:55 AM
