Th400
Old Jul 4, 2011 | 03:00 PM
Stevec's Avatar
Th400
My trany doesnt seem to kick down to 2nd gear when I go to full throttle but it up shifts and down shifts with no problem during normal driving/cruising. Could it be the vaccume mod is bad or out of adjustment? This engine produces plenty of vaccume. Thanks.
Old Jul 4, 2011 | 05:00 PM
TripDeuces's Avatar
There is an electric downshift solenoid bolted to the valve body. It has a spade connector that goes to the one wire plug in the case on the drivers side just above the pan rail and to the rear of the gear selector lever.
1) Solenoid is bad.
2) No power source to downshift switch or a break in the wire
3) Downshift switch isn't working. (I think yours is above the gas pedal inside the car)
4) Downshift switch needs adjustment
Hooking a 12v power source to that spade connector should give you an audible click from the solenoid
TRW
Jan 21, 2011 05:38 AM
ls442
Nov 11, 2010 10:45 PM
78Delta88
Sep 18, 2004 09:58 PM
cutlass72
Jan 2, 2004 05:26 PM
