Th350 tranmission problem with 3rd gear
Old January 25th, 2010, 07:38 AM
CHEV VAN's Avatar
I have a TH350c which had a master overhaul kit. Which had 1 mok,1torque converter tc ,1pump assy pa, 1 forward drum fd, 12 qts. fluids atf, 1 filter all done on 01-13-2010. The same day I pick the van up it want go into 3rd gear unless you first go to neutral and back to dr. then it go into 3rd. When you check the fluid lever, it be the same as with the engine running or not the fliud lever be the same about 3in past full.
now that reading also the same after driving it over 20 minutes. I brought this to they attention they said that ok for the fluid lever to be over, and for not going into 3rd gear you just need a tune up. Its still doing the same thing now 01-23-2010 That all... I NEED SOME REAL EXPERT HELP IN THIS MATTER. Its a 1981 . THANKS
CHEV VAN is offline
Old January 25th, 2010, 07:51 AM
Limey's Avatar
I am not an expert when it come's to transmission's BUT it say's do not over fill for a reason. I would drain some of that fluid and hope it didnt damage the new build.............and then see if you still have the prob's
Limey is offline
deuce442
May 13th, 2015 02:03 PM
hookem horns
January 29th, 2015 10:53 AM
Arrowstorm
May 20th, 2014 05:23 PM
1965cutlassragtop
July 1st, 2012 02:00 PM
bccsrc
July 23rd, 2008 01:22 PM
Quick Reply: Th350 tranmission problem with 3rd gear
