th350 swap
th350 swap
72 cutlass 350
tranny on "last leg"
-car manual not handy and need to budget for parts shopping
-need specs
-need to know what other common parts that typically get replaced during swap
- engine build is mild (slightly modified but hp unknown)
-primary use is daily driver/cruiser
-want to swap automatic for manual/automatic as I think it'd be more fun to drive yet still allow for lazy weekend cruise
-thinking of swapping stock trans for TCI STREETFIGHTER
(summit p/n: 311100)
thank you
-need specs
thank you
Things to inspect and or replace,
Trans mount
brake cables (look for frayed or loose cables)
u joints
Others may think of more.
I always inspect as much as I can when under my car. Look at fuel lines and brake lines and bushing and so on. Always good to check it all.
Trans mount
u joints
![Thumbs up](https://classicoldsmobile.com/forums/images/icons/icon14.gif)
with the exception to the U-joint , all of that has already been replaced but thx !
Torque converter.
Why not have a local shop rebuild your existing TH350 and install a Trans Go shift kit? That should cost several hundred dollars less than the Summit transmission. I recently had mine rebuilt for $800 including torque converter and that was the shop removing and replacing it.
Torque converter.
I guess you aren't aware that any TH350 can be manually shifted; you don't need a TCI transmission to get that function. Installing a shift kit can enhance that feature on the TH350 by giving you the ability to downshift at any speed. This also gives you the capability to blow your trans or engine if you downshift at too high a speed/RPM.
While it looks like a good idea, what if there are probs with the new trans? How will these be resolved?
Have you even looked into a local trans shop or three and get an estimate?
If you don't have patience for a rebuild how will your patience get stretched when you get to remove the trans and send it back for repair/replace. Not that this will happen but what if it does. I think working with a local place can curb these type of headaches. And to me part of the fun of hot rodding and doing car things is learning how to do all things including trans overhaul. If you can get a trans in and out, overhauling one shouldn't be too much trouble.
That's just me. Maybe you get a core to overhaul and then swap it in to reduce the time you car is down.
Let us know how you make out with what you decide.
