TH350 Leak From Yoke Air Hole
What is the current consensus on fixing a leaking yoke weep hole near the front u-joint? There are so many schools of thought on so many threads. I want to do the most prudent fix.
Some have plugged the weep hole with: JB Weld, brazed it, or used a Fitzall plug. Others have replaced the yoke with one that doesn't have a hole. Others replace the internal O-ring on the output shaft -- not a 100% solution for some, and not 'permanent' as the O-ring will need to be replaced again at some point. With all of the many seals on the trans, it would be nice to eliminate even one, if it wouldn't cause subsequent trouble.
Some say the hole is there to allow the tail to "breathe" when the drive shaft moves in/out on the output shaft. Others say the main trans breather hole on the top of the case will allow for that.
Has anyone had any issues after plugging the hole? Should I replace the O-ring and plug the hole?
Thanks for your input.
If I recall, there were two types: One with a hole, and one without a hole, but also missing one spline, so that the missing spline would vent the air that needs to move when the yoke telescopes.
I think.
I did have this problem at one time though, and I know that the PO had epoxied the hole, the epoxy had come off, and that I then brazed the hole closed, and I THINK I replaced the O-ring.
God, can't remember every detail now.
I think.
Thanks all.
I'm going to replace the output shaft O-ring inside the sleeve/cup. If the annoying drip isn't stopped, I'm plugging the hole. I have not read any post, on any forum, anywhere that mentioned a subsequent problem from plugging the hole (brazing it, putting a screw in it, using a Fitzall designed to plug it, etc.).
It would seem that if the hole is for air pressure relief (i.e. breather), then I don't want to have a new O-ring and plug the hole. That would / could result in some air pressure between the output shaft O-ring and the rear tail housing seal when the drive shaft moves in/out. So, it's one or the other, but not both. There can't be very much air pressure into the whole tail housing if the hole is plugged but the O-ring is removed.
This is correct. And if you don't have the missing spline, the air has to be vented either out the yoke hole, or into the tail housing ... but if the O-ring on the output shaft is new and sealing correctly, there's no vent if the hole is plugged.
costpenn
April 11th, 2012 07:25 PM
