TH350 Gear Whine
Old Sep 15, 2016 | 09:20 PM
77ricbaez's Avatar
TH350 Gear Whine
My Cutlass has always had a whine in FIRST GEAR ONLY, like if it were a muncie rock crusher. Shifts well, no other noise coming from the transmission.
Just wondering if it is normal for the THs to make the gear whine noise in first.
Also I should add that the pitch corresponds to the RPM, and if i drive it in Low gear and let off the gas the pitch goes down like the muncies do (and there's a bad-a** exhaust popping too)
Old Sep 15, 2016 | 09:56 PM
don71's Avatar
same but different
I don't mind a little whine in those gears. I consider that normal, with out other symptoms, I wouldn't worry about it.
Popping in the exhaust, leads to other problems. That could indicate incorrect timing or tune up issues.
Old Sep 16, 2016 | 08:08 AM
jpc647's Avatar
IS the bad add exhaust pop when you let off after winding up first gear? Leads me to think the car is pig rich and the unburnt gas is "exploding".
Old Sep 16, 2016 | 12:05 PM
77ricbaez's Avatar
Yes I drop it in first and wind it up to about 2000 RPMs and let off
Old Sep 16, 2016 | 12:21 PM
76olds's Avatar
Hookers under Hood
The whine is normal, I use to get it through the original radio. Running it up to 2k shouldn't be an issue at all once you let off. As Don mentioned, its sounds like you need a tune up with timing put into it.
Eric
Old Oct 26, 2016 | 03:31 PM
goatwgn's Avatar
Whine is just noise from the planetary gears. Usually first and reverse do it in TH350s. They did it in mine until the gears themselves actually broke after two "freshen up" type rebuilds when it had close to 500000 miles on it. The replacement makes the same noise. Even the TH400 in my old Pontiac makes a little bit of the same whine. I wouldn't worry about it.
Old Oct 26, 2016 | 04:07 PM
Have some cheese with the whine..., if its not ungodly loud its normal. The popping can be an exhaust leak also.
Old Oct 27, 2016 | 06:42 AM
oddball's Avatar
IIRC one major part of the TH350 spins at twice input shaft speed when in first, and that gets noisy. Intermediate drum? I'm trying to think back 15 years here....
I've had 6 or so TH350's, they all did it.
Seff
Nov 30, 2014 07:57 AM
W30Olds
Drivetrain/Differentials
20
Dec 12, 2013 03:54 PM
1BOSS83
Jul 18, 2013 07:58 AM
86ChebbyWagon307
Jul 5, 2011 07:09 PM
woodie582
Sep 19, 2008 11:14 AM
