TH350 Fluid Overfilled
Hi,
What is the recommended way to drain excess fluid from the trans? When I had the vehicle at the shop for some suspension work, I asked them to see if they could see where the trans leak was coming from. They filled it with fluid but not properly as the level is at the top of the marks on the dipstick when cold. Needless to say now I have no idea where the leak is coming from but before I tackle that, I want to make sure I take out the excess fluid to avoid causing any damage. Can I siphon from the dipstick tube to avoid removing the pan?
