Th 400 and 2 spd converter interchangeable??
SO I picked up a rebuilt long shaft 400 for really cheap with no converter I think it was from a buick. The numbers on the rectangular tag on the side are OA-69-1331 and I have the orig 2 spd in my car now. Im wondering can I use the converter from my 2 spd? Will it act like a stall? Also how do I tell if its a switch pitch trans? Its in a 66 cutlass convertible that came with the high compression 330 with a factory 4bbl. Can I convert the 400 to a switch pitch set up? If the 2 spd is a switch pitch can the converter be used without making the trans a switch pitch??? Im kind of confused. I really appreciate any help. Im hoping to get this into my car ASAP..
Andy
Andy
Switch/Pitch trans have a two prong plug on drivers side just above the pan rail. Top pin is to energize the S/P solenoid.
S/P converters do interchange between models but they can be different diameters 12 or 13 inch if I remember right. You'll get higher stall with a smaller converter.
Yes you can convert the TH400 to S/P. Requires a new pump and input shaft among other things. Jim Burek at PAE used to sell this conversion but looks like he's no longer in business. Joe P knows more about this.
No the converters do not interchange it ones a S/P and the other isn't.
If you have an original 2-speed in a '66 cutlass, it is not a Powerglide, it's a Jetaway.
Completely different transmission.
As Alex, er, Deuces, says, a S/P converter is unique, and can only mate up with a S/P pump.
If your new trans is S/P, you need to pick up a S/P converter, and then rig a way to control the converter pitch (manual switch, custom electronics, etc.). Not sure why you'd want higher stall when you've got a S/P, which is already a switchable high-stall / low-stall trans.
oldsmosteel
May 3rd, 2013 09:59 AM
2blu442
March 24th, 2013 09:47 AM
