Is the TH 350 working properly
65 post sport coupe w/425
Alright guys, now that I'm road worthy and driving the car I'm into some final tweaks and I'm focused on the tranny. I've got a few questions. As a reminder I've got the following power plant pushing a 1965 F-85 Cutlass:
425 (from 1967 dynamic)
rebuilt bottom up
.030 over on Egge 10:25 pistons
Federal Mogul Sealed Gap Rings (file gapped)
C heads (unported but rebuilt)
Engle JM 20-22 Cam with 110 lobe seperation
Cloyes Double Roller TIming Chain
Edelbrock Performer Intake
Edelbrock 750CFM Carb
MSD HEI Ignition (plug and play version)
NO STALL CONVERTER (STOCK)
How I can tell if it's working properly? I modified the kick down cable bracket and vacuum hose? Manifold vacuum at the Carb is 14-15hg at 650 rpms and a solid 20 at 950RPMS. I'm getting tire burning tourque through 2nd gear but concerned that I'm not shifting properly at highway speeds. Running 65-70 mph there's no downshift when I stomp on it. Is that normal? Also it doesn't seem to be downshifting correctly on the hills putting more load on the engine? Any thoughts or suggestions on what I can measure, test or do? What is normal? Sorry but looking for any tid bits that will help. Thanks.
rebuilt bottom up
Don't remember now as I did it some time ago. Is there an easy procedure to check adjustment?
Also, tranny is shifting better as it turns out, I did have a vacuum leak in the back of the manifold where I had a fitting blanked off. The rubber cap had a crack and the leak was sizable. It seems to be shifting well now around 28 or 30 into 3rd, When I stomp on it running about 55 it will downshift. I do not get a down shift much beyond 55 or 60 though. Is that normal?
1977 Delta 88 Flint
December 25th, 2012 04:23 PM
rida142
September 12th, 2010 07:37 PM
