TH 350 Trans seal
Old Aug 1, 2016 | 09:33 AM
Oldssupreme's Avatar
Chris
TH 350 Trans seal
Hello. Can anyone explain the proper procedure for removing and replacing the rear tail seal for the TH350 trans? Thanks!
Chris
Old Aug 1, 2016 | 12:07 PM
Chris
Remove the driveshaft
Pry out the old seal with a seal puller
Install the new seal with a seal driver or correct diameter piece of pipe
Install the driveshaft
Old Aug 3, 2016 | 05:55 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Be aware that if the rear seal is leaking, quite often the bushing is worn and needs replaced at the same time.
Old Aug 3, 2016 | 10:08 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Careful that the seal removal tool doesn't gouge the tail case seal surface when your prying out the old seal. That will cause a leak. Clean tail case with brake cleaner. Remove any burrs. Apply a THIN film of RTV to either the case or the OD of the seal. Drive it in equally so as not to distort the seal. Oh and palm or finger in (apply) Vaseline on the back side of the seal. This helps keep the tension spring in place when you slip the slip yoke back in....slathered with ATF before insertion of course. Check the slip yoke for grooves and burrs as well. Do not use grease on the back side of the seal.
Old Aug 3, 2016 | 06:12 PM
Chris
Much appreciated everyone! I'm sure I'll be back with more questions as soon as I get into it.
Chris
70rocketpilot
Aug 4, 2018 06:10 AM
cutlassKing
Nov 29, 2010 03:05 PM
1973olds98
Jun 6, 2010 09:08 AM
dharlett
Sep 23, 2009 03:30 PM
Sixoh
Aug 8, 2006 05:11 AM
