switching from m21 to m20
Old Jun 5, 2012 | 02:20 PM
Jeff Kashishian's Avatar
Hello..I am replacing my close ratio m21 with a wide ratio m20..I just noticed that the nipple on the end of the input shaft is longer on the m20..is this going to be a problem when installing?
Old Jun 5, 2012 | 02:49 PM
Rickman48's Avatar
No - Everythings interchangeable.
Old Jun 5, 2012 | 03:13 PM
thanks
Old Jun 5, 2012 | 03:52 PM
jensenracing77's Avatar
do you want to trade you M-21 for another M-20?
Old Jun 5, 2012 | 03:59 PM
MX442's Avatar
I'm guessing someone cut it to fit a non 4 speed crank. If your crank is not drilled for the input shaft, then you will have to cut the M20 and use a conversion bearing. Or pull the crank and have it machined for the correct bearing.
skryla
Oct 17, 2013 07:04 AM
desert442
May 21, 2013 01:36 PM
fast67vellen2o
Sep 27, 2010 12:18 PM
skryla
24
Mar 14, 2010 07:26 AM
Aceshigh
Jan 18, 2010 11:06 AM
