Switch Pitch TH400 switch
I have checked the solenoids in my transmission and they click with voltage, but I have no electric kickdown and wonder if the switch pitch is working. Is the switch repairable, or does anyone have a known good one?
Recent post here for big cars but switch is same.
https://classicoldsmobile.com/forums...vicing-149216/
Do you get power from the pedal switch? Noted in above post. Maybe the contacts inside are burnt or worn.
Like what Ed said. I think you should, off the top of my head, get no power to the kickdown until floored, and get power at part throttle only to the switch pitch. There's three contacts on the armature, one is ign power in and the other two are the two outputs mentioned.
If you simply jumpered 12v to the terminals, then do you know the switch is providing 12v to the trans? Check for voltage at the connector when you step on the gas. If none, trace the circuit to figure out why.
