ST 300 Shifting late
Old May 13, 2023 | 02:22 PM
Bearnecessities's Avatar
Hi all new here,
Have a 1969 Cutlass S with 350 original motor with a few upgrades. Car had a big 750 cfm Holley on it when I got it, and it drove fine as far as the trans was concerned. I just installed a 4bbl Quadrajet which operates fine, but now the trans is shifting late and hard. Did a trans service last year and since then it has sat for a couple of months during the winter in my garage. Checked vacuum line to the trans and fluid level is good, any one have any thoughts on what may be going on?
Thanks for the input
Old May 13, 2023 | 02:29 PM
What is your definition of "late"?
Old May 13, 2023 | 02:30 PM
It could be that the vacuum line from the carb is on ported vacuum, a bad modulator, or low vacuum in the line. It could also be a mis adjustment of the kickdown switch due to changes in the linkage geometry from the carb change.
Old May 13, 2023 | 04:33 PM
Late would be almost 3k rpm and not what I'm used to in this car
Old May 13, 2023 | 04:38 PM
So the kick down is a switch by the gas pedal no linkage. It is on a ported vacuum line on the Quadrajet so I guess that's my issue I need full manifold vacuum.
Thanks all much appreciated.
Old May 13, 2023 | 05:14 PM
Ported vacuum is zero at idle and small throttle openings, then follows manifold vacuum as the throttle blades open enough to fully expose the ports. This will definitely cause problems with part throttle shifting.
Old May 14, 2023 | 06:11 AM
Hammerdrop's Avatar
Doesn't this car have a TV cable going to the transmission ?
Old May 14, 2023 | 06:20 AM
No, it's an electric kickdown switch.
Old May 14, 2023 | 01:47 PM
Seems even the un-ported tube on the quadrajet did not have enough vacuum either, so I went right into the manifold works like a charm.
Old May 14, 2023 | 02:30 PM
Glad you got it fixed.
olds 307 and 403
61
Jun 13, 2021 07:21 PM
442craig
Apr 13, 2021 07:52 PM
llittles
Aug 13, 2017 04:59 AM
Olds1971
Jun 8, 2014 07:32 PM
nofiveo
Nov 29, 2013 06:08 PM
