speedometer gear housing for a 22 teeth driven gear
Old Oct 7, 2019 | 05:29 PM
Docs72's Avatar
I currently have a 1971 TH350 transmission with factory green 9 teeth drive gear and orange 35 teeth driven gear. Changed the tires to P235-60 R 15 and the rear axle gears to a 3.23.
Through searches on this site I need to change my driven gear to a gray 22 teeth for my speedometer to be at least close to the correct speed. I have a speedometer housing for 35 to 39 teeth and I know there is one for 40 to 45 teeth is there one for the 22 teeth or do I use the 35 to 39? Any help greatly appreciated.
Thanks Lewis
Old Oct 7, 2019 | 11:23 PM
svnt442's Avatar
Thanks Lewis
You need to change the drive gear. Get an 18 tooth gear for a 700R4 (same size as for a TH350) and a 45 tooth driven gear and you should be about as close as you're going to get.
Old Oct 8, 2019 | 11:47 AM
Docs72's Avatar
Thank you for your reply. I was hoping it would be a fast and easy fix but I guess I will be installing a new 18 tooth drive gear! again thank you for the information and reply.
Old Oct 8, 2019 | 01:03 PM
PATC - they have fairly quick service and can hook you up. They're in Louisiana. https://transmissioncenter.net/shop/...er-drive-gear/
I used them for my drive gear changing out my TH350 to 3.42:1. Good pricing. They have a toll free number if you need to talk.
Old Oct 8, 2019 | 02:31 PM
Docs72's Avatar
Thank you Allan I appreciate the link.
Old Oct 8, 2019 | 07:20 PM
svnt442's Avatar
How did that work out Allen?
Old Oct 8, 2019 | 07:50 PM
Just fine Randy, They're a great company to do business with. I ordered the Drive gear and tailshaft reseal kit from them. I already had the driven 39 tooth. The adapter I had in the car fits the 39 tooth. It was stubborn to get out. One thing to note: if replacing the driven gear, always a good thing to replace the adapter O ring.
Old Oct 8, 2019 | 08:02 PM
svnt442's Avatar
I'm glad that fixed your calibration issue and that I could help.
jwr7042
Tech Editor's Desk
Jul 3, 2018 07:48 PM
4SPEED67
Feb 21, 2018 05:41 PM
jpc647
29
Sep 8, 2017 09:02 PM
W-27
Drivetrain/Differentials
Aug 13, 2013 01:05 PM
Beltman
15
Oct 14, 2010 04:10 PM
