Speedometer Driven gear for M-21 w/342:1
Old Aug 13, 2013 | 08:57 AM
W-27's Avatar
I just installed a differential with 342:1 gear ratio with 31 spline axles (originally 308:1 with 28 splines) and i know i need to change the speedo driven gear but i just dont know which one to use or how do i calculate it (regular 14" wheels). Where is the best place to purchase it? I could use some help on this one. Thank you in advance.
Old Aug 13, 2013 | 09:18 AM
http://speedometersolutions.com/
Old Aug 13, 2013 | 09:56 AM
svnt442's Avatar
My guess would be you'll want a 20 or 21 tooth driven gear. Based on the chart.
Old Aug 13, 2013 | 01:05 PM
W-27's Avatar
Thank you guys!
Thank you guys for the info, i called Speedometersolutions.com and they were very helpful. They told me to (1) measure the exact eight of the tire, (2) take the presently installed driven gear and count the teeth & finally mark tooth of drive gear than count all teeth of drive gear. I was told to call them back with the results after which they will recommend a driven gear for it (i am guessing 20 or 21 at this point). Hoops, i didnt realize that my manual shop had this information as well. Thanks guys!
truckerlary
Jan 29, 2015 01:14 PM
StarGeneral
Nov 28, 2014 11:51 AM
2w-30s
May 14, 2013 03:20 PM
442b
Oct 14, 2010 02:46 PM
Erinyes
Mar 14, 2010 06:43 PM
