Replacing a Hydromatic with a standard Transmission
Old Jun 1, 2012 | 05:53 AM
renutter's Avatar
Would be possible to replace a 1950 hydromatic with a three speed manual transmission from a 1953 Chevy? The motor is a 1957 Oldsmobile 371 CI. Thanks.
Old Jun 1, 2012 | 07:24 AM
Tedd Thompson's Avatar
Don't think so, you would need a Olds or Cadillac transmission of 49 57 year range (may be other years). The unique bell housing on the Olds makes it difficult with out a very expensive adapter....Tedd
Old Jun 1, 2012 | 07:59 AM
renutter's Avatar
Thanks for the info.
Old Jun 1, 2012 | 08:24 AM
rustyroger's Avatar
'87 Delta 88 Royale
You might want to find a complete pedal arrangement from a donor car as well, and the shifter could also be a problem.
The crankshaft might need machining for a pilot hole for the input shaft too.
Not a simple bolt in swap but it can be done. Why do you want to put a stick shift in anyway?, it would be a lot less trouble to fit a 350 or 400 transmission although again not a case of simply bolting it on and driving away, the driveshaft and transmission mounting will almost certainly need to be altered and the speedometer drive could be another issue.
I don't want to be a wet blanket but be aware of what is involved before you start work.
Good luck,
Roger.
Old Jun 1, 2012 | 10:01 AM
renutter's Avatar
Thanks Roger. Right now I am exploring alternative solutions. I have considered the 350 or 400 trans. The car in its former life did have a standard trans as it still has the clutch pedal. I think it came from the factory with the hydromatic and was switched sometime before it was restored. I want to get rid of the hydromatic because I have had nothing but problems and it does not shift very well. Thanks for your time and info. P.S. I am also trying to sell the car as another solution but hard to sell with a bum transmission.
guy.graziano
Jun 13, 2012 05:33 AM
warren l
Jul 4, 2010 12:22 PM
Wes
Aug 21, 2006 01:26 PM
