Rear axle identification delta88 ´75
Old November 21st, 2013 | 03:17 AM
Delta88conv455's Avatar
Can anyone say what is this rearend?
Gear ratio is i believe 2.56
Previous owner told that it is HD rearend.
9.375 Olds 'O' type?
Old November 21st, 2013 | 07:54 AM
76 Regency's Avatar
Hi,
There is a code on the front side of the axle tube on the passenger's side of the car. You may have to scrape off some crud and/or undercoating to see it. You can decipher the code in the service manual. If you don't have the manual, post the code on here and somebody will be able to tell you which rear it is.
Is your car registered on the '75 Olds 88 Convertible registry?
http://www.1975oldsmobileconvertible.com/
Old November 21st, 2013 | 08:12 AM
507OLDS's Avatar
That is what I call the "large 12-bolt" It' is a 12-bolt cover,with a big 12-bolt ring gear.This is not the same as a 12-bolt Chevy,12-bolt Truck,or 12-bolt O-axle.
What car did it come out of?
Old November 21st, 2013 | 11:59 AM
76 Regency No i have not registered.
507OLDS it's from my´75 delta88royale 455
I'll have to check this code thing, thanks for advice.
Old November 21st, 2013 | 12:03 PM
76 Regency's Avatar
You should definitely register your car. If I remember right, there were only a few hundred 455 models. Yours being out of the US makes it even more interesting.
73aussie455
February 12th, 2014 02:06 PM
Bob Kelso
Drivetrain/Differentials
November 17th, 2013 04:24 PM
D Appeldorn
April 18th, 2011 01:45 PM
cutlasssupreme71
February 22nd, 2011 12:40 PM
mutzi
July 22nd, 2009 06:16 PM
Quick Reply: Rear axle identification delta88 ´75
