Rear axle identification delta88 ´75
Old Nov 21, 2013 | 02:17 AM
Delta88conv455's Avatar
Can anyone say what is this rearend?
Gear ratio is i believe 2.56
Previous owner told that it is HD rearend.
9.375 Olds 'O' type?
Old Nov 21, 2013 | 06:54 AM
76 Regency's Avatar
Hi,
There is a code on the front side of the axle tube on the passenger's side of the car. You may have to scrape off some crud and/or undercoating to see it. You can decipher the code in the service manual. If you don't have the manual, post the code on here and somebody will be able to tell you which rear it is.
Is your car registered on the '75 Olds 88 Convertible registry?
http://www.1975oldsmobileconvertible.com/
Old Nov 21, 2013 | 07:12 AM
507OLDS's Avatar
That is what I call the "large 12-bolt" It' is a 12-bolt cover,with a big 12-bolt ring gear.This is not the same as a 12-bolt Chevy,12-bolt Truck,or 12-bolt O-axle.
What car did it come out of?
Old Nov 21, 2013 | 10:59 AM
76 Regency No i have not registered.
507OLDS it's from my´75 delta88royale 455
I'll have to check this code thing, thanks for advice.
Old Nov 21, 2013 | 11:03 AM
76 Regency's Avatar
You should definitely register your car. If I remember right, there were only a few hundred 455 models. Yours being out of the US makes it even more interesting.
73aussie455
Feb 12, 2014 01:06 PM
Bob Kelso
Drivetrain/Differentials
Nov 17, 2013 03:24 PM
D Appeldorn
Apr 18, 2011 12:45 PM
cutlasssupreme71
Feb 22, 2011 11:40 AM
mutzi
Jul 22, 2009 05:16 PM
