Proper speedo drive gear
Running a 3.08 rear end behind a TH 400 which I believe is a 1:1 as a 3 speed.
Is there a way to calculate or know the proper speedo gear color/tooth count for that overall set up?
The tire is a 15" but where I'm lost is the drive and driven gear.
I have no idea what the drive gear tooth count is.
The chart that woodie put up shows a range of tooth counts and leave me even more lost on this.
There is a speedo gear calculator on TCI transmission FAQ. As Joe mentioned, you need to know the axle ratio, tire diameter, and preferably either the drive or driven gear tooth count. Enter that info, it will calculate the other gear needed.
Sometimes you will come up with drive or driven gear that has no match for your tire/gear ratio. When that happens you need to play around with changing both gears to come up with an acceptable combination. Furthermore, you need to make sure the driven gear will fit the existing housing, or make sure you order the correct part.
Unfortunately sometimes even that doesn't work, which is why GM occasionally had to use ratio adapters from the factory.
Still can't wrap my head around this.
The tire od is 26"
The calculator asks for the drive gear tooth count of which there could be 9 different gears.
I take it the driven gear housing must come out to see the color to know that.
I think the problem is the original rear end was 342 with a 14" tire.
Now its a 308 with a 15" (26 od) and the speedo reads about 10 mph higher.
Then we have 19 driven gear possibilities....
Lastly what is Aspect Ratio and how does it factor into this?
The tire od is 26"
The tire od is 26"
The tire od is 26"
This example needs a driven gear with 42.5 teeth. Obviously you can’t have a gear with half a tooth, either a 42 or 43 is needed
Changing the drive gear gets the needed driven gear closer to a whole number.
The closer to a whole number the more accurate the speedo.
My blind shot in the dark would have been a common gear used in these cars, and yes no guarantee the trans is original.
Its going on the lift for a trans filter change, I will dig in when that happens.
Never would have thought there would be that many drive gears for the number of driven gear combinations honestly.
Thanks for the help.
Consider that the TH400 was used in everything from F-body cars with small diameter tires to two ton trucks with very tall tires, and with rear axle ratios from 2.14:1 to 5.00:1 (and above for the big trucks).
There's a straight-forward way to determine the tooth count you need...
- count the number of teeth on the driven gear in the trans.
- drive at exactly 60 mph as indicated on your speedometer.
- have someone simultaneously use a smart phone GPS app to determine your actual speed.
- divide 60 by the GPS speed and multiply by the number of teeth on the existing driven gear.
- the result is the number of teeth you need on a new driven gear.
The ID tag on the passenger side of the trans will tell you where it originally came from, and the VIN derivative stamp on the driver's side will tell you if it's original to the car or not. In any case, the original rear could have been 2.56, 2.78, 3.08, 3.23, 3.42, 3.91, 4.33, or 4.66 ratio. The Product Information Manual says that for 3.08 gears, the drive gear in the TH400 was 18 teeth.
Great info
So would that mean that in order for this 308 to read proper speed I'd have to change the drive gear in the transmission?
Or would it reason that once I know the drive gear tooth cound I could find the correct or close driven gear with the calculator?
Depends on how far off the current drive gear is. If it's close, you can probably make due with a different driven gear, possibly with a ratio adapter. There's more than one way to get to the right combo.
Engr
You would change the drive gear or get a ratio adapter only if your calculation shows that you need a driven gear with a number of teeth outside the 34 to 45 availability.
If you're still unsure, post the color (or tooth count) of the existing drive and driven gears along with your GPS and speedo readings. We'll help you select the correct gear.
Finally getting back to this with the car now up.
The drive gear is coded with yellow paint.
Is there is chart that shows the teeth count coded yellow?
The driven gear is orange and marked 35T.
Speedo is running about 10 mph fast.
Kinda glad I went there because I found the speedo cable nut cracked in 3 places.
She is pretty grimy but hasn't given me a reason to pull and overhaul it.
Last engine was leaking pretty badly.
Orange driven gear checks out at 35 teeth as you indicate.
You will need to put in a Yellow driven gear (41 teeth).
The drive gear does not need to change and you do not need a ratio adapter box.
Your speedo will read 0.4% (one-quarter of an mph) slow. But this accuracy depends on how carefully you measured your speed at 60 mph indicated.
Your statement "speedo is running about 10 mph fast" could indicate that you didn't use GPS or stopwatch. You also didn't state at what indicated speed you checked actual speed.
Last edited by VC455; November 25th, 2022 at 12:09 PM. Reason: added base speed qualifier
When the speedo reads 75, I am close to 65 mph.
Thanks for the help, 4% is close enough for me.
I was able to cancel and reorder the housing and 40T in time.
ty
Hey Joe,
May I revive a 9 month old post on which you were assisting a member in selecting the proper speedometer gear, please? My situation is that I purchased a '69 4477 with an M20 and factory A/C. That tells me that it should have come with a 3:23 axle ratio (it is open); however, the transmission, which was divorced from the car when I purchased it, did not have the housing or a gear in it. I am running a set of Firestone G70x14 Wide Ovals (not radials, but bias belted) tires on the car mounted on steel 14" stock rims. What are your thoughts on the correct teeth count/color for the speedometer gear in this car?
Thanks!
Buddy
Thanks!
Buddy
Hey Joe,
Thanks!
Buddy
Thanks!
Buddy
Yes, I knew that the F70 was the correct size for the '69 Wide Oval, so is the external adapter necessary to compensate for the difference in tire size? I've found a 25 tooth gear, but finding the external adapter for that particular ratio is a little more challenging. If I don't install the adapter, I'm assuming the speedometer reading will be off by what...15-20%?
Thanks Joe!
Thanks Joe!
#31
Thanks Joe!
Thanks Joe!
