Problem using old torque convertor?
Old April 20th, 2009 | 09:32 PM
Jonb442's Avatar
Problem using old torque converter?
The original converter for my '69 442 has been sitting 15+ years, and I'd like to use it again once I get the car together. It functioned fine before I removed it. Will I have a problem using it again after it sat for so long? I plan on eventually swapping in a TH2004R so it will be somewhat temporary. Also, does anyone by chance know if the lower flywheel cover is the same between a TH400 and TH2004R? Thanks!
-Jon
Old April 21st, 2009 | 07:25 AM
Originally Posted by Jonb442
The original convertor for my '69 442 has been sitting 15+ years, and I'd like to use it again once I get the car together. It functioned fine before I removed it. Will I have a problem using it again after it sat for so long? I plan on eventually swapping in a TH2004R so it will be somewhat temporary. Also, does anyone by chance know if the lower flywheel cover is the same between a TH400 and TH2004R? Thanks!
-Jon
Torque converters do have internal bearings and bushings that can wear out. If you really only intend for this to be temporary, go for it, but in my experience, "temporary" tends to last several years.
Old April 21st, 2009 | 08:33 AM
jaysun's Avatar
ate glue as a child
Depends on how it was stored. if it was stored covered you should be ok. However if it was stored uncovered , it would of accumulated dust and junk, over the years, and the trash will circulate through the transmission. and the transmission cooler. (specifically the lube system). However they can be cleaned either by a tranny shop or by you, if your brave enough. It requires drilling a smalll hole in a specific place and a special rivit.
Also i believe that most hydraulic fluid,including transmission fluid, is hydroscopic (absorbs water) in nature. i'd remove as much of the old fluid in the converter as possible and flush the converter with a quart or two of fresh fluid. water in the fluid causes clutch failure.
/usual disclamer/ not a tranny expert but learning
Jason
Old April 21st, 2009 | 07:24 PM
Jonb442's Avatar
Thanks guys. I think I'll flush it out and run it. I guess if/when it breaks that will be the time to swap to a 2004R.
-Jon
CrazedCountryRebel
May 21st, 2011 01:54 PM
CrazedCountryRebel
May 17th, 2011 10:44 AM
Wasted
October 7th, 2009 01:14 PM
handsomened
March 29th, 2007 04:00 PM
