Problem using old torque convertor?
Problem using old torque converter?
The original converter for my '69 442 has been sitting 15+ years, and I'd like to use it again once I get the car together. It functioned fine before I removed it. Will I have a problem using it again after it sat for so long? I plan on eventually swapping in a TH2004R so it will be somewhat temporary. Also, does anyone by chance know if the lower flywheel cover is the same between a TH400 and TH2004R? Thanks!
-Jon
-Jon
The original convertor for my '69 442 has been sitting 15+ years, and I'd like to use it again once I get the car together. It functioned fine before I removed it. Will I have a problem using it again after it sat for so long? I plan on eventually swapping in a TH2004R so it will be somewhat temporary. Also, does anyone by chance know if the lower flywheel cover is the same between a TH400 and TH2004R? Thanks!
-Jon
-Jon
Depends on how it was stored. if it was stored covered you should be ok. However if it was stored uncovered , it would of accumulated dust and junk, over the years, and the trash will circulate through the transmission. and the transmission cooler. (specifically the lube system). However they can be cleaned either by a tranny shop or by you, if your brave enough. It requires drilling a smalll hole in a specific place and a special rivit.
Also i believe that most hydraulic fluid,including transmission fluid, is hydroscopic (absorbs water) in nature. i'd remove as much of the old fluid in the converter as possible and flush the converter with a quart or two of fresh fluid. water in the fluid causes clutch failure.
/usual disclamer/ not a tranny expert but learning
Jason
Jason
