Overdrive Transmission
Old May 2, 2007 | 03:24 PM
72RocketPower's Avatar
A few months ago I posted asking if anyone new the best way to swap an overdrive transmission into a 72 cutlass supreme with a 455/th400 powertrain with a column shifter. I was wondering if anyone has any updated information for me.
I know that TCI sells a th700r4 that looks like a good candidate. Yearone sells an adapter plate for the 700r4 to the back of the engine as well as a shifter conversion kit. Would the drive shaft need modification for this to work. would a different torque converter be needed? What else would need to be done?
Thanks for the help!!!
Old May 2, 2007 | 04:09 PM
Shop around for the adapter plate - lots of vendors sell them. Try Summit and Jegs. This is the standard Chevy to BOP adapter.
Here's some more info on fitment and dimensions:
http://archive.classicoldsmobile.com/html/63.html
Old May 26, 2007 | 07:23 PM
acolds's Avatar
Why not 2004R no need for adaptor the ratios are closer together can be made to take high horsepower TCI also sells a version
redvettemike
Dec 20, 2012 05:07 PM
KEVO35
Bravada
Dec 8, 2012 08:44 AM
skryla
Mar 2, 2011 08:01 AM
projectheaven
26
Aug 9, 2008 11:26 PM
72RocketPower
Drivetrain/Differentials
Jun 29, 2006 02:37 PM
