Olds dynamic 88 transmission help pleas
Old Jun 1, 2022 | 01:24 PM
Dgurkan's Avatar
I am new to the oldsmobiles and want some info on my trans, the engine is a 396 ci in a 1962 rocket 88, can anyone tell me what this trans is, and if there is anyway to help it change better without loosing drive for a second when I put my foot down, I have adjusted the TV cable and ir has new oil which did make it better, and if anyone knows where I can buy a good trans filter that would be awsome help many thanks,
Old Jun 1, 2022 | 01:43 PM
Welcome. Your engine is a 394 first generation Oldsmobile and has nothing in common with the Chevy 396. That trans is the Rotohydramatic 10, popularly known as the Slim Jim. It has a number of idiosyncrasies including that poor shift quality. Trans filters and parts are available from Fatsco.
https://www.fatsco.net/_files/ugd/ff...1a64abcdc5.pdf
Old Jun 1, 2022 | 06:53 PM
Charlie Jones's Avatar
Phantom Phixer
Be very careful about adjusting the TV rod. Proper operation depends on accurate adjustment'
The proper adjustment procedure is outlined in the 1961 Oldsmobile Service Manual. ( get the 62 supplement too )
Jaswest makes the special adjustment gauge.
These transmissions shift much differently than Turbo Hydramatics.
First gear is very low, to get the heavy car moving quickly.
Then there is a long " jump " to second gear with a drastic ratio change.
Then a short " hop " to third.
1961 1962 Oldsmobile Shop Manual CD Olds 88 98 Service Repair Dynamic Super | eBay
JASWEST - Product Catalog
G Boss
Apr 21, 2022 04:17 PM
Brownie12
Mar 24, 2022 06:02 PM
Brownie12
Sep 16, 2021 05:47 PM
d'sdad
Dec 16, 2013 05:22 PM
wookie dave
Jun 11, 2008 02:41 PM
