O-Ring Size for Detent Cable
Old Aug 2, 2016 | 09:25 PM
Toms cutlass's Avatar
I've replaced several transmission gasket seals (speedo seals, fill tube, gear selector shaft, front & rear seals) and installed new cooler lines on my 350TH automatic. No more leaks, however I want complete peace of mind and need to replace the original seal on the detent kickdown cable. What is the exact size of the detent O-ring (couldn't find in existing threads)? Also, can I use the new-and-improved tophat type seal on the detent cable rather than the O-ring? I've read differing thoughts. Thanks in advance.
84oldsDelta88
Sep 30, 2011 09:20 PM
Tony72Cutlass'S'
Jul 22, 2011 10:26 AM
jerseyjoe
May 5, 2011 06:49 AM
69 Cutty
Aug 24, 2006 08:16 PM
