no kickdown on 400
Old Jul 29, 2009 | 10:20 AM
slumpy's Avatar
Question no kickdown on 400
hey, my 400 trans my brother in law told me has no kickdown for passing gear hooked and he sees no way of hooking one up, i have the 403/400 turbo setup, and trans was just rebuilt before i traded for it, so what are my options? i now just manually shift down to the next gear. also it has a eldelbrock 4 barrell if that makes a diff. thanks.
Old Jul 29, 2009 | 12:20 PM
citcapp's Avatar
B & M transmissions makes a kickdown switch the mounts to your carb linkage on the intake manifold. I installed one on my 455 on my 57 Olds, works great
http://www.bmracing.com/PRODUCTS/B-M-Catalog-Online
Old Jul 29, 2009 | 01:15 PM
All you need is a switch controlled by the throttle that provides +12V to the solenoid terminal on the trans at wide open throttle. You can either retrofit a factory switch or use an aftermarket one as suggested above.
Old Jul 29, 2009 | 05:59 PM
slumpy's Avatar
thanks, ill check the 12v switch out for sure..
n_holman
Jun 2, 2013 02:49 PM
Gearhead442
Jan 27, 2011 03:03 AM
sbFALL63
Jan 23, 2011 09:01 AM
sbFALL63
May 28, 2010 05:45 AM
ziff396
Apr 13, 2009 03:57 PM
