Need help...
Old Oct 26, 2011 | 09:48 AM
Redline442's Avatar
Need help...
Tranny fluid leaked out on the way home the other day. Checked the lines, they seemed to be intact. Not sure what else to check and where. Any and all suggestions would be appreciated. 455 engine, no clue as to what transmission!!! Thanks!
Old Oct 26, 2011 | 10:00 AM
AZ455's Avatar
1974 DELTA 88
Where does it seem to be coming from now that it is parked? Pan, dipstick, modulator, kickdown solenoid connector (assuming it's the TH400)? Also check up near the torque converter, you will have to pull the plastic converter inspection cover to see up in there, but the pump seal could be leaking.
The problem with trans leaks is the fluid runs everywhere and makes it hard to find the source, especially if you have been driving. Clean it up and keep an eye on it.
Old Oct 26, 2011 | 10:03 AM
Oldsmaniac's Avatar
Or you could be burning it up thru the vacuum line from the trans modulator to the intake.
Old Oct 26, 2011 | 10:43 AM
If its not on the ground, there are only 2 other places for it to go. The radiator, generally when this happens the trans fills with water, but I have seen the opposite. The other place is it gets sucked into the intake or carb, and is burnt!
Old Oct 26, 2011 | 01:34 PM
Redline442's Avatar
Thanks for the replies...It all leaked out while driving and finished in the driveway. Pulled the plastic cover, couldn't tell anything. Honestly, didn't know what to look for. Thought about adding more trans. fluid and seeing where it comes out!!
Old Oct 26, 2011 | 03:52 PM
Thats a good idea, depending on the pan it could hold as much as 8-9 quarts. You should be able to look underneath and see where its leaking from! I've also found if you lay cardboard under there you can see where its dropping from and look straight up! Gravity is a law!!
meoff
Site Help
Aug 29, 2013 12:15 PM
coppercutlass
Mar 1, 2013 07:33 AM
cutlassclay
May 11, 2012 06:31 AM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
