Need dimension from the pilot bearing hole
Hi,
I need help withe the dimension of the pilot bearing hole.
Because I want to change later to 5-Speed manual I want the pilot bearing drilled in the crank now, because it's at the machine shop.
Can someone please so kind and give me the correct pilot bearing hole dimensions or the dimensions of the pilot bearing itself.
THX Jörg
THX Jörg
When I had my crankshaft drilled for manual transmission usage I sent a bushing with it and had it installed. Do you have the bearing or bushing you plan to use yet? When I purchased my bushing the vendor had 3 different bushings with 3 different outside diameters available
Hi,
THX Jörg
THX Jörg
here is the link to the two diagrams. I used the top one.
https://classicoldsmobile.com/forums...-question.html
Aceshigh
January 27th, 2011 04:28 PM
