Need '71 Cutlass Supreme kickdown cable 350 turbo
Old December 12th, 2014 | 10:12 AM
eazy's Avatar
From: Malvern, PA (Hometown) Williamsport, PA (College)
As title states I need a kickdown cable ASAP. I have my trans pan dropped in attempt to replace my siezed up cable. The one I ordered was the wrong one. I need the cable that goes thru the firewall from the throttle pedal to the trans. It does not have an i hook connection in the trans, more of a straight rod with a bend. Either way, i need something that will work. Does anyone have a cable they can sell me? I am starting to think the part is obsolete. Any advise always appreciated.
Old December 12th, 2014 | 12:26 PM
Any of the resto aftermarket parts houses, OPGI, Yearone, etc...
Old December 12th, 2014 | 01:23 PM
2coupe's Avatar
Try NAPA part#1-7364 worked on my 1970.
Old December 12th, 2014 | 02:25 PM
1001coins's Avatar
i have one located in chicago
Old December 12th, 2014 | 03:57 PM
eazy's Avatar
The cable I ordered was from Yearone. It's a plastic p.o.s., and I wouldn't use it on my go-kart.
Thanks for the reply though.
Old December 13th, 2014 | 05:59 AM
drop top olds's Avatar
I purchased mine from Fusick. It was correct, and works properly. The sheath was "plastic" but the inside was braided steel cable. Good Luck with your search.
Old December 13th, 2014 | 07:08 AM
Macadoo's Avatar
I honestly don't remember where I got mine. I think it was from Advance Auto. A piece of advice; lubricate the cable before you install it. Get some cable lube for motorcycles. Mine tends to stick. And when it sticks the tranny won't shift.
Old December 13th, 2014 | 08:21 AM
The stock cable is a plastic sheath. The cable is braided steel.
Old December 14th, 2014 | 06:28 PM
MattP_15's Avatar
I had ordered a duralast kick trans kick down from autozone and the cable on the inside would not pull when it was out through the firewall. Someone told me about fusick so I ordered a kick down from them and it went in perfect with no problems
Old December 16th, 2014 | 01:05 PM
eazy's Avatar
I have determined that the cable I ordered is supposed to work. It's being installed today. Turns out the i hook on the stock cable siezed up inside the housing, so all I saw was the rod sticking out which is why I thought I had a different cable. Thanks for the help. I should be good to go now.
Old December 16th, 2014 | 09:33 PM
Macadoo's Avatar
Same thing that happened to mine. Glad you're getting 'er fixed up.
Old December 16th, 2014 | 09:47 PM
Octania's Avatar
CABLE, KickdownCable TH350 to firewall, 1971 1972 Cutlass
NAPA part number ATP364 detent cable 1969-72 Cutlass
411340 CABLE, downshift or detent, 69-72 F85 TH350
4210 CABLE, downshift or detent, 69-72 F85 TH350.
Cable runs to FIREWALL and GAS PEDAL; Also on box from Advance Auto:
015-3841-6, 91-32-107254414, SKU=3925188, Barcode 51784
Crossovers: CA-1950, Y-104 [Made in Israel]
nj67
July 25th, 2014 05:08 AM
at3reg98
July 4th, 2012 11:14 AM
dallasite21
October 27th, 2010 09:55 AM
rocketscientist
March 11th, 2010 05:30 PM
