Muncie M22
Old Nov 15, 2021 | 09:35 PM
Bigfish45's Avatar
Muncie M22
Were there any 1968 Oldsmobile that could be ordered with a Muncie M22 transmission? If so, would it have been a 660 casting on the main case?
Old Nov 16, 2021 | 04:10 AM
jensenracing77's Avatar
Only Oldsmobile with an M-22 was a 1971 442 W-30 4 speed car. Did they even make an M-22 in 68 for anything? I was thinking the M-22 come out in 70 or 71? I could be wrong on that part.
Old Nov 16, 2021 | 04:35 AM
jmos4's Avatar
Looks like 67 according to the Motor Trend article
"The M20 and M21 transmissions produced from 1963-'74 are easy to identify in both wide- and close-ratio units. The M22 to come later in 1967-'74 is also a close-ratio unit, but much stronger than the M21, with a higher torque capacity."
https://www.google.com/amp/s/www.mot...smissions/amp/
Regards,
Jim
Old Nov 16, 2021 | 05:35 AM
The M22 was not factory available in any 1968 Olds.
Old Nov 16, 2021 | 07:22 AM
Andy's Avatar
I believe an M22 with-a 220 first gear first came out in 1966..fine spline M22 was the 71 and up trans, 26 spline.
Old Nov 16, 2021 | 07:50 AM
Bigfish45's Avatar
The Muncie M22 first evolved in 1963 for Corvette Grand Sport racing program. In 1965 the first 57 M22s were built for production vehicles.
Old Nov 16, 2021 | 09:41 AM
Andy's Avatar
I thought it was 1966 but after seeing your comment, yes it appeared in a few vettes and other chevrolets I believe in 1965..nice work.
Old Nov 16, 2021 | 10:17 AM
Are you sure that is a Muncie? The code number may have been used but that would have been a BW in 1963. The 1963 Cutlass had an M-20 4 seed option code but it was a BW and not a Muncie.
Old Nov 16, 2021 | 12:11 PM
Interesting info, but I don't know what it has to do with the OP's question.
Old Nov 16, 2021 | 03:34 PM
Andy's Avatar
Joe, now Joe, you know we like rabbit holes..lol
Old Nov 16, 2021 | 07:23 PM
And I'm as guilty as anyone.
Old Nov 19, 2021 | 07:12 AM
He is the OP.
Jordans1970OldscutlassS
Jun 17, 2019 03:40 PM
L69
Sep 24, 2015 05:35 PM
w45stick
Aug 13, 2015 07:53 PM
2coupe
May 9, 2013 12:47 PM
fast67vellen2o
Dec 3, 2010 11:13 AM
