modulator
Old Jul 16, 2022 | 02:28 PM
70-455's Avatar
modulator
I want to adjust the modulator on my turbo 400 to stretch the shifts a little more.Do you turn clockwise or counter clockwise?Also is it a allen screw or skinny flat head screwdriver?Thanks.
Old Jul 16, 2022 | 02:51 PM
You can adjust the modulator with a small slotted screwdriver. Turn the adjustment screw clockwise to raise shift points and counter-clockwise to lower shift points. Note, the shift point change is minimal, around 5 mph total. Also you can turn the screw too far clockwise to where it will fall inside the modulator rendering the adjustment useless.
Old Jul 16, 2022 | 02:54 PM
70-455's Avatar
modulator
okay thanks.
Old Jul 17, 2022 | 07:59 AM
You can change shifts points 2-4mph at most. If you need a bigger change, you need to play around with the governor.
Jun 27, 2022 04:53 PM
rg442w30
Oct 5, 2013 06:56 AM
FAZ442
Jul 12, 2012 06:04 AM
turnpike_cruiser
Jun 26, 2010 05:47 AM
turnpike_cruiser
Jun 25, 2010 12:31 PM
