modulator
You can adjust the modulator with a small slotted screwdriver. Turn the adjustment screw clockwise to raise shift points and counter-clockwise to lower shift points. Note, the shift point change is minimal, around 5 mph total. Also you can turn the screw too far clockwise to where it will fall inside the modulator rendering the adjustment useless.
