M22 RPMs
Manual transmission conversion - questions and options
Am I correct in calculating that with a M22 and a 1:2.73 rear, doing 75 in 4th gear is going to take about ~4400 RPM? If this is so, I'll have to look for a 5 or even 6 speed tranny.
Last edited by Seff; March 10th, 2011 at 07:37 AM. Reason: More suitable title for the thread
5 speed or 6 speed won't matter i don't think. if i am thinking right only the last gear in each will be overdrive. i don't think that the 5th gears in a 6 speed is overdrive but i may be wrong.
Now, if you meant a final drive of 3.73:1, then the engine is turning about 3600 RPM at 75 MPH. With 4.33 gears, you'll be turning 4200 RPM.
It's impossible to answer this question without knowing the tire size. Assuming you have a 26" tall tire, fourth is 1:1 (as it is for any non-OD GM transmission) and with a final drive of 2.73:1, at 75 MPH your engine will be turning about 2650 RPM. I have no idea where you got 4400 RPM.
That was what I was basing my assumptions upon. Glad that it isn't actually like that. :P Thanks for the replies.
According to this, some 5 speed trannys have overdrive (less than 1.0, yes?), while none of the 4 speed trannys get below 1.0.
Ah, suspected so, thanks.
Semi-related questions - when looking for transmissions for my 1972 Cutlass Supreme, I can make most GM transmissions bolt up to my 350 either directly or with an adapter plate like this one, yes? Am I going to need my torque converter with the manual transmission? When looking for a pedal, will any/most do, or do I need an A-body or even a Cutlass-specific pedal assembly?
Please note my very carefully worded response in my first post:
Note that Chrysler also had a four speed where the top gear was OD. This was actually used in Chevy trucks for a while. Both the Chrysler and Ford OD 4spd transmissions were stop-gap responses to the first oil crisis in the 1970s. It was easy to change one gear ratio to improve gas mileage. Both of these transmissions actually put the OD gears in the THIRD gear location, so third was the 1:1 former fourth gears and the OD fourth was the former third gears. The tab on the shift arm was flipped to keep the new third and fourth in the same location in the H pattern.
