M21 stuck in second
M21 stuck in second
My M21 had been giving me problems shifting from 2nd to 3rd.
Now it is stuck in second and I cannot even get neutral.
Anyone got a fix?
Thanks in advance.
Derek
Anyone got a fix?
Thanks in advance.
Derek
Disconnect the rods from the trans. Manually put the levers in the trans on neutral. Put the shifter in neutral (you may have to move the levers individually) and use a 1/4" still but through the alignment hole on the levers to lock them in place. Now adjust each for correctly.
i used to lay on my back at the side of the road,reach under with one arm, pull a lever forward i think, always burn my wrist on the exhaust, and swear i would never speed shift from 2nd to 3rd again
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Disconnect the rods from the trans. Manually put the levers in the trans on neutral. Put the shifter in neutral (you may have to move the levers individually) and use a 1/4" Drill Bit through the alignment hole on the levers to lock them in place. Now adjust each for correctly.
Auto populate can play tricks too. One of my former companies was getting ready for a big layoff. The head of HR was sending a copy of the termination agreement to an attorney named Allen. She was one of those people that was in a lot higher position than she should have ever been. It auto populated to "All" and she sent it to everybody in the company. She scrambled and tried to recall it but somebody had already opened it and it was too late. True story.
skryla
October 17th, 2013 07:04 AM
fast67vellen2o
September 27th, 2010 12:18 PM
