M21 stuck in second
Old Apr 23, 2016 | 06:54 AM
Rocket North's Avatar
M21 stuck in second
My M21 had been giving me problems shifting from 2nd to 3rd.
Now it is stuck in second and I cannot even get neutral.
Anyone got a fix?
Thanks in advance.
Derek
Old Apr 23, 2016 | 06:57 AM
You have to physically get under the car to free it up. Is this something that just started?
Old Apr 23, 2016 | 07:55 AM
Disconnect the rods from the trans. Manually put the levers in the trans on neutral. Put the shifter in neutral (you may have to move the levers individually) and use a 1/4" still but through the alignment hole on the levers to lock them in place. Now adjust each for correctly.
Old Apr 23, 2016 | 08:01 AM
Octania's Avatar
"use a 1/4" still but through the alignment hole on the levers to lock them in place. Now adjust each for correctly."
use a what?
One assumes auto-co-wreck fixed this for you
Old Apr 23, 2016 | 08:06 AM
use a what?
Yeah, new phone...
Old Apr 23, 2016 | 08:39 AM
stan 65 cutlass's Avatar
i used to lay on my back at the side of the road,reach under with one arm, pull a lever forward i think, always burn my wrist on the exhaust, and swear i would never speed shift from 2nd to 3rd again
Old Apr 23, 2016 | 03:06 PM
AzMotorhead's Avatar
Disconnect the rods from the trans. Manually put the levers in the trans on neutral. Put the shifter in neutral (you may have to move the levers individually) and use a 1/4" Drill Bit through the alignment hole on the levers to lock them in place. Now adjust each for correctly.
Fixed it for you
Old Apr 23, 2016 | 04:12 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I had to think about what auto-co-wreck was. Then it came to me.
Old Apr 23, 2016 | 06:12 PM
wr1970's Avatar
Yeah auto correct can really screw things up.
Old Apr 24, 2016 | 07:06 AM
Octania's Avatar
One of my faves, which get documented on the internet
Wife: do you think I am fat?
Her man enters "Noooo"
The phone "corrects" that to "Mooooo"
Old Apr 24, 2016 | 08:27 AM
redoldsman's Avatar
Auto populate can play tricks too. One of my former companies was getting ready for a big layoff. The head of HR was sending a copy of the termination agreement to an attorney named Allen. She was one of those people that was in a lot higher position than she should have ever been. It auto populated to "All" and she sent it to everybody in the company. She scrambled and tried to recall it but somebody had already opened it and it was too late. True story.
skryla
Oct 17, 2013 07:04 AM
desert442
May 21, 2013 01:36 PM
fast67vellen2o
Sep 27, 2010 12:18 PM
skryla
24
Mar 14, 2010 07:26 AM
Aceshigh
Jan 18, 2010 11:06 AM
