M20 sqealling and grinds going into reverse.
Old Jun 7, 2024 | 02:33 PM
ben442's Avatar
I just did an engine swap. Clutch was good, installed a new throw out bearing, it moves freely on the input shaft.
Clutch pedal is adjusted with no play at the pedal and trans grinds trying to engage reverse.
Did I adjust it in the wrong direction? The adjustment rod is turned out to fill the space between the clutch fork and the Z bar. Spring is installed.
Also what would be causing the squealing noise when I step on the clutch? Oil or grease contamination?
I'm going to drop the trans and inspect tomorrow, just looking for advice on what to look for.
Old Jun 7, 2024 | 04:11 PM
fleming442's Avatar
The squealing is basically unpossible to diagnose over the internet.
As for grinding in reverse, that's pretty normal, as it is not synchronized. Try putting it in 1st prior to reverse; that should fix that.
Old Jun 7, 2024 | 04:19 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Or the TO bearing is upside down or not engaged properly on the retaining spring.
I have pics somewhere Ill try to dig up.
Old Jun 7, 2024 | 05:26 PM
Also, why no freeplay at the pedal? It should have about 3/4".
Old Jun 7, 2024 | 06:07 PM
ben442's Avatar
I'm not trying to change how much free play the pedal should have. I think I just over did it on the adjustment. I'll redo that first, loosen it up and see what happens.
Old Jun 7, 2024 | 07:17 PM
joesw31's Avatar
First, reverse should not grind. Second, it sounds like your clutch is not completely disengaging. Make sure your clutch disc is not bent by making sure you have sufficient air gap. Lastly, your release bearing sounds defective. Hope this helps
Old Jun 8, 2024 | 05:59 AM
Andy's Avatar
Hopefully you got the throw out bearing clipped in correctly. It’s easy to do wrong. Usually you will have a very hard clutch if it’s clipped wrong..ask me how I know..lol
Old Jun 13, 2024 | 01:04 PM
ben442's Avatar
follow up....
found the problem....
broken retaining clip on the clutch fork
replaced the clutch fork and new throw out bearing and all good.
the tip on the left side of the retainer is broken off, causing the throw out bearing not seat right.
Old Jun 13, 2024 | 01:05 PM
ben442's Avatar
Thanks for the thoughtful solutions.
Old Jun 13, 2024 | 09:31 PM
Thanks for the follow up. Its so important to do.
Next guy that has the problem can do a successful search.
stevdak
Jun 2, 2022 04:01 AM
Bfg
18
Oct 25, 2017 04:31 AM
Peter Lufrano
Feb 22, 2016 07:21 AM
Cincinnati Rick
Aug 3, 2015 07:08 PM
Oldsmaniac
Aug 14, 2011 04:51 PM
