Looking for Olds 4GC and Slim Jim Expert in DFW
Old Jan 25, 2016 | 12:11 PM
fv64olds98's Avatar
Hello All,
I have a 1964 Olds 98. The Slim Jim Transmission was recently re-built and the carb was rebuilt by me. The issue I am facing is that when I accelerate from a stop, some times the car shuts down. The other issue I am having is that the transmission seems to not be shifting at the proper time and sometimes when I am driving into my garage uphill on the driveway, I have to press the gas very slow, if I press it hard it will shut off. When I drive the car in the highway or past 1st gear it seems to drive fine.
I am looking for someone with experience on two areas.
1. Get the carb tuned properly
2. Get the TV rod setting to the transmission setup correctly
Regards
Old Jan 26, 2016 | 09:41 AM
Don R.'s Avatar
Can't help on local service but it sounds like your accelerator pump may not be working, might be a simple fix you could do yourself. check to see if you are getting a fuel squirt in the carb when the throttle is opened.
Old Jan 26, 2016 | 11:53 AM
rocketraider's Avatar
Oldsdruid
Make sure you put the right throttle body gaskets in the 4GC. Some have extra vacuum bleeds cut in them that will create hard to diagnose problems, and uphill bogs are one of them.
Also check distributor vacuum advance.
Old Feb 18, 2016 | 06:30 AM
ripper27's Avatar
Originally Posted by fv64olds98
Hello All,
Regards
Did you come up with a fix for your carb and trans , I had same problem with my 62 , I have spare carb I put new gaskets in because wrong gaskets were in throttle body and caused vacuum leak , but winter set in so did not have time to put it back on car , the one I have on car now seems to cut out between shifting from 1st to 2nd think that might be accelerator pump , have to see what I come up with once I get car out of storage in the spring , toke me month to find out it had wrong gasket in it , there are no markings on the Rochester carbs to tell what model it is , could not find anybody around were I live to work on a Rochester , having same problem with trans nobody around here wants to touch the old slim jims ,
Old Feb 18, 2016 | 01:30 PM
Chesrown 67 OAI's Avatar
[QUOTE=fv64olds98;889554]Hello All,
Regards[
Youve got one of the worlds best Olds carb and transmission man right in your backyard in Cleburn, TX -- maybe 40 miles from Ft Worth?
PM me for info.
Old Feb 19, 2016 | 09:17 AM
Don R.'s Avatar
[QUOTE
PM me for info.[/QUOTE]
The rest of us in Texas (and elsewhere) with 4GC's and Slim Jims could use this information, can you share with the group?
Old Feb 19, 2016 | 11:23 AM
Originally Posted by Don R.
[QUOTE
PM me for info.
The rest of us in Texas (and elsewhere) with 4GC's and Slim Jims could use this information, can you share with the group?[/QUOTE]
x2?
f-85
Oct 24, 2009 06:20 AM
NAS Backyard
Jul 3, 2009 04:47 PM
64starfire
Jun 22, 2009 09:47 PM
GeneS12320
Apr 28, 2008 06:39 AM
