Lightning Rod shifter question
Old Apr 16, 2011 | 07:19 AM
jensenracing77's Avatar
i have a set of beautiful lightning rods but the 1/2 and 2/3 shifter would not shift. i took it all apart and found there are little clips that hold a spring loaded rod in place on the bottom of each shifter. this clip looks like a spring ring type of clip that is used also for a bushing to guide the rod into place as you use it. does anyone know where to get these clips? i will try to post a picture of it later.
Old Apr 16, 2011 | 07:44 AM
2blu442's Avatar
Eric, if you don't find the answer here you might try over at Oldspower.com There's a lot of members with the 1978-88 vintage Oldsmobiles on that site.
John
http://www.oldspower.com/vb/index.php
Old Apr 16, 2011 | 12:12 PM
thanks john, i just registered there. here are some pictures of what i am talking about.
100_1578.jpg?t=1302980969
100_1582.jpg?t=1302981052
100_1579.jpg?t=1302981081
Old Apr 18, 2011 | 05:24 PM
i think i have an idea. i am going to take one of the levers to the hardware store and see if i can find a roll pin that fits right. if i can i will try to cut it real easy so i don't get it hot and loose the temper. i hope it works because i don't know what else to do.
Old Apr 18, 2011 | 06:12 PM
GAOldsman's Avatar
"Car"mudgeon
I can't tell from the pics if it is a Hurst set up, but if you can't find the parts you can always have them rebuild it for you if it is a Hurst. Hopefully this helps.
http://www.hurst-shifters.com/c.7230...r_rebuild.html
Scot
Old Apr 18, 2011 | 06:28 PM
thanks, i didn't know they still did this. i was told they shut down the rebuild service. i just wonder if they will sell me just the little spring rings? i don't need them to rebuild it. this one don't have any wear other than the two little broke rings.
Old Apr 18, 2011 | 06:34 PM
GAOldsman's Avatar
"Car"mudgeon
Hmm it's worth a try. I suppose you could contact them tomorrow.
Scot
Old Apr 19, 2011 | 05:25 AM
Lady72nRob71's Avatar
The guys there at oldsgmail.com might be able to help, also...
They specialize in the G body Cutlass.
Old Apr 19, 2011 | 06:39 AM
Franks442's Avatar
I am the original owner of an 83 H/O. There was one time that my linkage got stuck and I was unable to get it to shift out of first (handle locked up). Got the car to my dealer and they cleaned and regreased the linkage. Has been fine for the last 20 plus years. I know your issue is different but the dealer advised routine lubrication of the mechanism to keep it free and from prematurely wearing out parts. I have always worried about finding parts for this linkage. Please let us know if you find a source or repair option. Good luck.
Old Apr 19, 2011 | 07:19 AM
oldspower.com has a bunch of G body guys also
http://www.oldspower.com/vb/showthre...ight%27ing+rod
Old Apr 19, 2011 | 09:24 AM
Scot
lol, i called them and he said there is a reason they are so expensive when you find a good one. they don't rebuild them and don't make parts for them. they said that there is no chance of ever doing them. he was a cool guy to talk to but just couldn't help. he said he knew of a NOS one that just sold for $1500. looks like i will have to try the roll pin like i mentioned. i signed up for the other boards but they have not approved me yet.
Old Apr 19, 2011 | 09:43 AM
GAOldsman's Avatar
"Car"mudgeon
Man that stinks , I am truly sorry to hear that. I wish I could help, maybe someone can on one of the sites. Maybe if you have a competent machine shop nearby they could fab some up for you. Good luck either way. I hope they (Hurst) don't pull that with me if I need them. My dual gate is supposed to have a lifetime warranty, but then again is 39 years a lifetime to them??
Scot
Old Apr 19, 2011 | 10:01 AM
GAOldsman's Avatar
"Car"mudgeon
Try this guy.
Angelo Valentini
At the Oldsgmail Store or
5014 Elm Street
Skokie,Il 60077
847-845-0442 A fellow member of the Olds G-body mailing list, he now offers good reproductions of Lightning Rod shifter bezels, boots, and he's a distributor for Stencils and Stripes. He also offers a Lightning Rods rebuild service and frequently has many parts and/or a few sets on hand for sale.
Old Apr 19, 2011 | 01:13 PM
Scot
i ask about the other shifters. he said that an OEM dual gate is $175 if there are no major components bad and you don't need the stick chromed. a competition plus is $275.
Old Apr 19, 2011 | 01:14 PM
Try this guy.
Angelo Valentini
5014 Elm Street
Skokie,Il 60077
i'll try that, thanks.
Old Apr 19, 2011 | 01:20 PM
GAOldsman's Avatar
"Car"mudgeon
I've got my fingers crossed for you, I couldn't tell how old/new that thread was. Good luck!!
Scot
Old Apr 20, 2011 | 12:30 PM
Try this guy.
Angelo Valentini
5014 Elm Street
Skokie,Il 60077
is this guy 88hurstolds on gbodyforum?
http://gbodyforum.com/viewtopic.php?...25456&start=15
i can't get anyone to confirm me on the other boards and can't get in touch with the guy above? i have some real good ideas how to fix this problem but if i can just get the rings i would rather do that.
Old Jul 27, 2011 | 10:53 AM
84HO's Avatar
Lightning Rod Spring Retainer Ring
Were you ever able to locate replacement Spring Retainer Rings for your Lightning Rods? One of mine cracked and locked up my shifter, and I'd like to have a true replacement instead of creating my own. I would appreciate knowing what you ended up doing to remedy yours. Thank you! Dan K.
Old Apr 26, 2017 | 05:57 PM
Long overdue update. I did use a roll pin to fix this. I can't remember the size but cut it to the same width as the original and it press fit right in like the original.
Old Jun 26, 2018 | 05:15 PM
BADGAS's Avatar
I am trying to pull a Hurst Lightning Rod Shifter apart that has been in a huge fire when the shifter was in the Park position .
I have finally got the main lever to move from Park through to Drive .
I cannot move the center lever from Drive back to 2nd .
My main question is " What positions do all the levers have to be in so i can pull this shifter fully apart " ?
gearheads78
Sep 3, 2012 07:45 AM
jensenracing77
Apr 27, 2011 07:02 PM
JeremyTA
Mar 23, 2011 05:15 AM
w-30dreamin
Jan 2, 2010 09:53 AM
millwrightrice
Aug 17, 2008 03:13 PM
