Kickdown cable location
Old Aug 16, 2016 | 02:02 PM
Roger60's Avatar
Fitted a TH 350 to my 67 Cutlass 330. Would anyone have a photo showing location of the kickdown cable mounting? Thanks
Old Aug 16, 2016 | 02:09 PM
don71's Avatar
same but different
First question is what carb are you using? That is going to make a big difference since the kick down is throttle related. Throw up a pic if you can of what you're running Roger. That would help a lot.
Old Aug 16, 2016 | 02:43 PM
You do realize that whatever you do to attach the kickdown cable on a 67 will be custom, right? The 67 cars only came from the factory with an AT that used an electric kickdown (Jetaway and TH400).
Old Aug 16, 2016 | 03:38 PM
There are after market universal cable setups available that run from the carb linkage to the trans.
Old Aug 16, 2016 | 03:39 PM
Roger60's Avatar
67 ickdown
Thank you, I'm aware this is not stock. I have the original Quadrajet, converted to accept the detent cable. I have the new cable and an aftermarket bracket from Jegs. Just need to see where to bolt it up.
Old Aug 16, 2016 | 03:49 PM
You'll have to fab something to mount it. You can pickup a bolt/s on the manifold or make a bracket to attach off a carb bolt.
Old Aug 17, 2016 | 06:19 AM
The easiest and least expensive method is to simply get the throttle cable bracket and kickdown cable from a mid-70s Olds with TH350 and Qjet. Those cars ran the cable to the carb, not the accelerator pedal.
mhood
Aug 19, 2010 02:38 PM
rocketscientist
Mar 11, 2010 04:30 PM
PmL69
Mar 3, 2009 07:59 PM
mark8918
Feb 6, 2009 09:34 AM
bigbrother
Jun 18, 2007 12:34 PM
