Kick down switch Super Turbine
Old Aug 12, 2015 | 09:33 AM
pappy's Avatar
I'm supposed to have 12V at the kick down switch with ignition key on, right? If not, (I don't) where should I be getting the voltage from? Volt meter is only reading .03 at the red wire when disconnected at switch. ('65 F85) Thanks
Old Aug 12, 2015 | 01:57 PM
pappy's Avatar
Well, I found a blown fuse. Worky good now. Wonder what caused the blown fuse now.
Old Aug 12, 2015 | 03:30 PM
Originally Posted by pappy
Well, I found a blown fuse. Worky good now. onder what caused the blown fuse now.
Could be debris or wear inside the switch or could be a bare spot on the wire. Don't forget the wire from the switch to the trans, especially where it passes near the exhaust.
Old Aug 12, 2015 | 06:49 PM
pappy's Avatar
Checked wires from switch to tranny, no issues found except could be a tighter connection on tranny side would be nice.
Anyway, got to drive around to run a few errands. Working great and so far no blown fuses.
Got to get alignment tomorrow since newly installed coil springs on all 4 corners. mercy, what an improvement!
jcmoretti
Feb 8, 2015 11:03 AM
Bad68442
Dec 4, 2013 08:06 PM
1968Cutlassfallbrook
Aug 4, 2011 08:45 PM
1965cutlassragtop
Jun 24, 2011 10:06 AM
salisbury99
Jul 5, 2008 05:26 PM
