Jet away gurgling sound
Old May 16, 2021 | 07:01 AM
Boss Ross's Avatar
I have a 1957 Olds 88 J-2. Had the trans rebuilt, it makes a gurgling sound (like your stomach when it’s hungry) when taking off and when it shifts gears. Any ideas of the cure.
Old May 16, 2021 | 09:52 AM
Sugar Bear's Avatar
IF this was a TH350 which it isn't...I'd look for a bad or missing seal at the oil pickup at the filter or possibly reversed cooling lines to the rad. I don't know specifics about that transmission but the same principles may apply.
Good luck!!!
Old May 28, 2021 | 04:15 PM
supmarjo's Avatar
hi BossRoss
did you find out what it was / is ??... Low oil ?.....not enough oil in the fluid coupling ?
Old May 29, 2021 | 07:26 AM
Tedd Thompson's Avatar
Are you sure the noise is coming from the transmission and not from the heater core or radiator? Do you have any shudder taking off? And does the transmission dip stick show any froth or bubbles?..... Tedd
bruce geiger
May 10, 2017 08:45 AM
classic body works
Apr 26, 2016 03:12 PM
VI Cutty
Jun 3, 2015 08:56 PM
