Identify this part?
Old Jun 15, 2011 | 02:40 PM
AZ455's Avatar
1974 DELTA 88
Identify this part?
This looks like a sensor of some sort near the speedometer cable. Anyone know what sort of sensor it is, if that is indeed what it is? The trans is a bit greasy right now, the part in the photo seems to seep fluid (o-ring I assume). I haven't seen the ID plate on it, but based on the model/engine/exhaust configuration I am assuming a TH400. Thank you.
Old Jun 15, 2011 | 03:35 PM
svnt442's Avatar
If you look closely there is a missing pin that is broken off. That would be the connector for the kickdown and TCS solenoid switch on a TH400. From the looks of things there is only the black/orange wire (kickdown) in the photo and not a green one (TCS) so the pin was removed so the plug would fit on it.
Old Jun 15, 2011 | 03:55 PM
AZ455's Avatar
1974 DELTA 88
Yeah, I did notice that. Interestingly the plug does have a second slot in it, but no wire/blade connector in it. I thought it may be a kick down solenoid, but every one I have searched for on auto parts sites looks nothing like it.
Anyway, is this just pressed in with an O-ring?
Thanks!
Old Jun 15, 2011 | 03:56 PM
svnt442's Avatar
It's actually part of the valve body from what I understand. You can't remove it from the outside.
Old Jun 15, 2011 | 03:59 PM
AZ455's Avatar
1974 DELTA 88
Oh.. that is interesting. Guess it's gonna stay leaking for a while then..
Old Jun 15, 2011 | 04:11 PM
svnt442's Avatar
Scroll down to post 17. This seems to be a very detailed tear down of a TH400.
http://www.pirate4x4.com/forum/showthread.php?t=430754
Old Jun 15, 2011 | 04:26 PM
AZ455's Avatar
1974 DELTA 88
Thumbs up
Thanks for your help, that is a very informative post.
Old Jun 16, 2011 | 06:33 AM
That is not correct. The electrical connector is simply a plastic body that snap into the case and is sealed with an o-ring. It is not part of the valve body.
Old Jun 16, 2011 | 09:56 PM
svnt442's Avatar
Really. Can you remove it without dropping the pan, or does it all have to come apart like in the write up?
Old Jun 17, 2011 | 07:36 PM
AZ455's Avatar
1974 DELTA 88
I'd be interested in knowing this as well, it'd definitely be a time saver.
Old Jun 17, 2011 | 09:36 PM
Lady72nRob71's Avatar
Yep, gotta drop the pan...
JWO 4-2011 has a good writeup on this common connector leak.
Get a new connector (as it may be brittle and break on ya), drop the pan, disconnect wire inside, squeeze tabs that hold it in, and push it out. The new one will snap right in. Connect the wires and reassemble!
Old Jun 17, 2011 | 09:40 PM
AZ455's Avatar
1974 DELTA 88
Ah ok. Not too bad of a job. What type of ATF to you all use in these transmissions? Something like Castrol DEX/MERC?
Old Jun 17, 2011 | 09:49 PM
AZ455's Avatar
1974 DELTA 88
I have some of this stuff...
http://www.castrol.com/castrol/secti...tentId=7027043
The description sounds good to me...
JR_N_CHICAGO
Jan 15, 2014 12:01 PM
boondocker
Apr 4, 2010 04:21 PM
skubydobdo
Sep 19, 2008 06:15 AM
scott_442
Aug 16, 2008 04:27 PM
